Phone not charging, 15 RGS - Road Glide Forums
post #1 of 10 (permalink) Old 11-28-2014, 02:44 PM Thread Starter
Phone is not charging on either media port or cigarette lighter socket. Tried while riding and while swithed to accesory. Tried multiple different cords. It does hold the battery at the level it was when plugged in but doesn't add even 1 percent. Any ideas?
rangestrider is offline
post #2 of 10 (permalink) Old 11-28-2014, 05:08 PM
Is it an iPhone? If so are you using an Apple charging cable, or a third party one? Beginning with OS 7.01 and up Apple has made it that you need an authorized charging cable. Some people have reported some success with work-arounds, but it is hit or miss. You may also notice things like your touch screen is jumpy when trying to use it while it is plug into a non-authorized cable.
Technically, the phone measures the voltage across the cable, and it it does not measure up to Apple's specs it will not work properly.
larsfum is offline
post #3 of 10 (permalink) Old 11-28-2014, 11:15 PM
hook's Avatar
I would be inclined to use red lock tight on the charger cord plug at the phone, let it dry, then whip the phone as hard as you can into a deep body of water.
Then ride into the sunset.
2011 RGU
hook is offline
post #4 of 10 (permalink) Old 11-29-2014, 06:48 AM Thread Starter
No, it's a Samsung. Charged fine on the aftermarket "cigarette lighter" charger on my sportster, but not on the new RG.
post #5 of 10 (permalink) Old 11-29-2014, 07:12 AM Thread Starter
Well, the locktite would be one way, but I don't just ride to get away. I ride all day, every day, so at some point the phone has to get charged on the road. I wish I could jettison it and ride away.
post #6 of 10 (permalink) Old 11-29-2014, 09:24 AM
hook's Avatar
Joking about being tethered to the phone aside, there is an LED on my phone charger. If the LED does not come on bright after plugging it into the cig lighter, I have to pull it out, spin it a little and insert the charger plug again until a good connection lights the LED and the phone indicates it is charging.
Assuming the fuse is okay, and there is 12v at the lighter, only other thing that comes to mind is to connect that after market plug to the RG battery and see if that works.
2011 RGU
hook is offline
post #7 of 10 (permalink) Old 11-29-2014, 09:54 AM
Did you check the power ports too see if you had power there with a multimeter??
I would think if there is a problem with the power ports and cig lighter the dealer should fix it under warranty.
Or you can just shut the phone OFF and ride the bike and only turn the phone on in an emergency.
post #8 of 10 (permalink) Old 11-29-2014, 09:58 AM Thread Starter
Well, on both connections, the media port and the lighter, my phone indicates that it is charging but the charge won't rise only stay at the same level.
Will attempt to charge a different phone to test it.
post #9 of 10 (permalink) Old 11-29-2014, 10:14 AM
this only happens on the bike? when you charge in your home it charges fine? if so, are you able to use the same cable as the one being used inside the house? i have experienced charging issues with my samsung but not on the bike. have you tried pulling the sim and charging it? this has helped me in the past although it was an annoyance
whiskeyMO is offline
post #10 of 10 (permalink) Old 11-29-2014, 12:49 PM Thread Starter
Yep, I've used multiple cords. I just had success when charging with the phone off. That's all I need. As long as I know I have a charging method when out and about.
A Better Phone Mount Option 15-17 RGS? Larrys Ride Controls & Handlebars 21 05-15-2018 09:38 AM
2017 FLTRU glove box phone charging. Weak. HellInABucket *General Road Glide Discussions/Pictures 12 07-25-2017 02:38 PM
Wireless Phone charging for $25.00 Alcyone92 Do-IT-Yourself 0 03-30-2017 11:01 PM
Phone not Charging - 15 RGS AFD68 Audio 3 06-20-2015 10:52 PM
iPhone 4S - Charging/Not Charging dinggus Audio 8 11-01-2013 09:25 AM
