98 running lights - Road Glide Forums
post #1 of 19 (permalink) Old 12-11-2014, 01:29 PM Thread Starter
98 Road Glide's Avatar
98 running lights
I have a 98 road glide and I just lost the running lights in the rear. the turn signals still work but the running lights don't. is this a bulb issue? I checked the fuses and no wire brakes that I can see.
98 Road Glide is offline
post #2 of 19 (permalink) Old 12-11-2014, 01:54 PM
FDR's RGC's Avatar
Check bulbs, if you have a run, turn, stop module it may have went bad. Now post it a third time to see if you get more replies.
FDR's RGC is offline
post #3 of 19 (permalink) Old 12-11-2014, 02:02 PM Thread Starter
If it is a bulb issue do I have to get them from a dealer? This is my first Harley and not to familiar with it yet. Would the modular be near the fuse box?
post #4 of 19 (permalink) Old 12-11-2014, 02:09 PM
Bigtrev8xl's Avatar
You my son, are in need of a genuine workshop manual, for your year and model.
The chance of 2 bulbs blowing at the same time, is highly unlikely, to not going to happen.
I DON'T DO RUSHING!
Bigtrev8xl is offline
post #5 of 19 (permalink) Old 12-11-2014, 02:13 PM Thread Starter
Thank you. I guess I better go get one. The turn signals still work just not the running lights. I'm guessing I need to go the dealer and get one.
post #6 of 19 (permalink) Old 12-11-2014, 02:22 PM
Bigtrev8xl's Avatar
Probably, unless you can find a second hand one somewhere, ebay, etc
I DON'T DO RUSHING!
post #7 of 19 (permalink) Old 12-11-2014, 02:34 PM
bucketlisthd's Avatar
I'll bet stock is turn only.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #8 of 19 (permalink) Old 12-11-2014, 02:47 PM
PGR
PGR's Avatar
Bingo...... you beat me to it.
Pull a bulb and see how many elements it has. If it looks like the bulb below... it's turn signal only, and no running lights. The part number is 68572-64b. In a pinch, you can use an automotive 1156. But since your turn signals work, it's not necessary.
Ron..........................
PGR is offline
post #9 of 19 (permalink) Old 12-11-2014, 03:00 PM Thread Starter
the bulb is different. The numbers on the bulb are r7 ge 199. I know that they were working a few weeks ago. I had someone from work tell me that they went out.
post #10 of 19 (permalink) Old 12-11-2014, 03:19 PM
PGR
PGR's Avatar
Then it's not a stock setup if you had running lights. The part number of the bulb I gave in my previous post is the OEM part number for your rear turn signal bulb. And it should only have one element.
The numbers you gave from the bulb is a single element bulb. http://genet.gelighting.com/LightPro...DUCTCODE=37986
I just called a friend who has a 98 Road Glide Anniversary. His does not have rear running lights. Just turn signals.
Here's a shot of his 98
PGR is offline
No Turn Signals, Running Lights, or Brake lights on 15 FLTRXS warbird458 Lighting 5 07-12-2016 08:02 AM
Just wondering who running radial tires and who is running bias. Pros and cons please scsharp2260 Wheels and Tires 8 08-11-2013 08:20 AM
Front Running Lights 1st Sgt Troubleshooting for Road Glides 1 03-25-2012 01:33 PM
running lights AndyM Lighting 2 10-06-2011 09:39 AM
adding RGU running lights StriderJim Road Glide Specific Discussions 15 10-06-2011 08:27 AM
