2005 electrical shutdown What Gives? - Road Glide Forums
post #1 of 6 (permalink) Old 01-09-2015, 03:00 PM Thread Starter
Hi my 05 Roadie had a complete electrical shutdown,only the odometer and brakelight lit up. we checked all connections removed and checked the regulator it showed 12 volts on the 3 pins of the connector which my manual said makes it bad, reassembled to take to shop to have everything checked, Whala the thing started up everything worked and it is 14.4 volts charging. now I am scared to ride knowing it could happen again, Any thought on this. Thanks Mike
rocn7roc is offline
post #2 of 6 (permalink) Old 01-09-2015, 03:08 PM
PGR
PGR's Avatar
Corrosion on the pins. Clean every connection you had apart really well, and use a light coating of dielectric grease.
Ron..........................
PGR is offline
post #3 of 6 (permalink) Old 01-10-2015, 10:42 AM
I believe the 05 has the 35 or 40 amp breaker which has a history of going bad and shutting down the entire bikes electrical system.
When the breaker starts to go bad it will overheat and the breaker kicks in shutting down the system, the breaker will reset itself when it cools.
This is a common problem and replacing the breaker is the fix, many people replace the breaker with a 40 amp master fuse.
This is just one possible cause for you to check because there is many things that can cause electrical issues. Make sure to check all the ground connections too.
You voltage regulator will not cause the problem you have.
post #4 of 6 (permalink) Old 01-10-2015, 12:22 PM
+1... This is the problem I've seen a few times. pretty sure there was a recall and the Moco will fix that for You if You want them to.
V-man is offline
post #5 of 6 (permalink) Old 01-14-2015, 11:23 AM Thread Starter
Turned out to be corroded ignition switch took apart and cleaned applied dielectric grease.Hope this helps someone
rocn7roc is offline
post #6 of 6 (permalink) Old 01-15-2015, 01:15 AM
That would do it!
Glad you found the problem, a bad ignition switch isn't a very common problem.
Could Not Shutdown Security Alarm Phantom6722 Troubleshooting for Road Glides 5 05-15-2014 03:12 PM
2005 FLHT Electra Glide Standard electrical problem - FAST Help needed FLTRXpilot Troubleshooting for Road Glides 4 03-07-2014 03:20 PM
Govt' shutdown and vet/ret, soc/disabled pay 07Roadie General Off-Topic Discussions 20 10-10-2013 07:27 PM
Which headpipe gives the best torque? FLtroll Intake and Exhaust 2 04-07-2011 02:58 PM
