Radio will not power on - Road Glide Forums
post #1 of 3 (permalink) Old 01-11-2015, 05:40 PM Thread Starter
So I installed a set of RF T165's in the inner fairing of my 09 glide. I ended up taking the inner fairing off and using a hole saw to drill it out. When I took apart all the wiring harnesses I labeled everything. Now that I have put the fairing back on and connected all the wires, the harmon radio will not power on. I checked the fuse but it was ok. Any ideas?
Thanks
Fatboy9 is offline
post #2 of 3 (permalink) Old 01-11-2015, 05:57 PM
RD-GLIDER's Avatar
Ground connections are just as important as the others. Double check no pins worked their way out. Good luck
Sent from Motorcycle.com App
RD-GLIDER is offline
post #3 of 3 (permalink) Old 01-11-2015, 06:22 PM
perrykw's Avatar
Check all the wires. I had some warranty work done on mine and they ended up having to cut some zip ties. After that my left speaker didn't work. Once I finally had time to troubleshoot, found that they accidentally cut the speaker wires.
perrykw is offline
$799 Power Package Street Outlaw mufflers, Power Vision, FM Stage 1 AC fuelmoto Fuel Moto 7 06-16-2018 03:37 PM
LED's, power commander, power vision, and other items for touring models. Gasitman Parts for Sale 5 08-23-2014 01:29 AM
no power to radio after pulling tour pak texasridr Troubleshooting for Road Glides 8 01-06-2013 02:44 PM
Power for my Stratus 6 Radio whyjay Audio 2 04-15-2012 06:35 PM
Power Command Power Vision problem help! BigDave55 ECM/Fuel Management systems 11 08-06-2011 08:21 AM
