Cold Start/ Warm up - Road Glide Forums
post #1 of 9 (permalink) Old 01-17-2015, 07:44 AM Thread Starter
flhr95's Avatar
Cold Start/ Warm up
Starting the bike for the first time during the day the rpm's will go to 1500 then down to 1000 then back to 1500 and then back down to 1000, it will continue to do this for 60 to 90 seconds or until it warms up.
Any advice as where to look, I thought maybe the PCV but disconnected it and have the same issue at cold start.
Thanks
Chris
2010 Fltrx 96", Ness Stage 1 air set-up, V&H Power Duals with Hi Output Slip ons, PCV, SE204 Cams.
flhr95 is offline
post #2 of 9 (permalink) Old 01-17-2015, 09:04 AM
Both of my fuel injected bikes have done this, both before and after the tuners were installed. I think(I hope) it's normal.
xshovelfreak is offline
post #3 of 9 (permalink) Old 01-17-2015, 09:48 AM
Q-Hog's Avatar
Same here-
Q-Hog is offline
post #4 of 9 (permalink) Old 01-17-2015, 10:45 AM
Did you try cycling the ignition on/off 5 times?
When there is a idle problem cycling the ignition on then wait for engine light to go off then turn ignition off do this 5 times and should reset the idle setting in the ECM.
This may help, it works when the bike has high idle problems.
post #5 of 9 (permalink) Old 01-17-2015, 11:14 AM
Mine goes up to about 1500 for about 30 secs on cold starts then drops to normal idle. I believe that is normal. I did have an issue once about 2 years ago where the bike idled at almost 3000 rpms. I dealer told me about the idle reset that ironmark mentioned which i did, and it hasn't done it since. With both of my instances, the idle was steady. It sounds alil different than the OP's issue of the idle speed rising and falling. It may have something to do with the tuner
post #6 of 9 (permalink) Old 01-17-2015, 11:20 AM
kouack's Avatar
Same with mine too, i would not worry.
kouack is online now
post #7 of 9 (permalink) Old 01-17-2015, 06:03 PM Thread Starter
flhr95's Avatar
Thanks for the advice I will try the reset and see.
flhr95 is offline
post #8 of 9 (permalink) Old 01-17-2015, 06:16 PM
Mine does the same as rlaf75 . Cold start , goes to 1500 and stays there till warmed up then back to 1k.
post #9 of 9 (permalink) Old 01-20-2015, 07:20 PM
Biggy's Avatar
As stated it should have a cold start idle, mine is around 1300 with the Thundermax, then it drops to 890 when hot. But it should not go up and down, if you continue to see it worsen be sure to check the engine temperature sensor, mine had a broken wire and it went from a small idle fluctuation to a floating idle of 3k that took it's time back to idle or the sensors do go bad on occasion.
Sincerely, Tim
2007 FLTR
Biggy is offline
How cold is too cold to ride? kevinhd1690 *General Road Glide Discussions/Pictures 47 11-27-2014 10:36 PM
Too cold to Roadglide, too warm to snowmobile, what to do? mike General Off-Topic Discussions 8 01-18-2014 11:30 AM
Changing your oil. Engine warm or cold? Minivend *General Road Glide Discussions/Pictures 19 04-14-2013 12:11 AM
How Warm is Too Warm? Ran8175 *General Road Glide Discussions/Pictures 5 03-19-2012 01:36 PM
