Speedometer is really sporadic - Road Glide Forums
post #1 of 3 (permalink) Old 02-03-2015, 12:17 PM Thread Starter
G
G's Avatar
I can be moving down the road and the speedometer just drops out...down to zero. Then will start working again. No pattern to this, I've tried to duplicate it with no success. Speeds, gears, accelerating, decelerating...no pattern at all...just randomly drops and returns to working when it wants to.
I have seen than when it drops out and is on zero...occasionally the 6th gear light will flash and the turn signals won't cancel. Don't know if these are related, but it's very consistent when the speedo isn't working.
Don't know if it's mechanical or electrical.
Guess I'm going to have to take it to the shop, but before I do, wanted to get the best wisdom here so I can get the best results there. I'd appreciate your help.
Thanks!
DETERMINED to spend more time riding this bike and less time wrenching and customizing!
2011 FLTRX with 103. Rinehart 4" slip-ons (
). Stock head pipes. Chrome SE Ventilator Air Clean (
G is offline
post #2 of 3 (permalink) Old 02-03-2015, 12:28 PM
hometoast's Avatar
Sounds like it MIGHT be a bad speed sensor. https://www.roadglide.org/showthread.php?t=167793
Pull the codes (https://www.roadglide.org/showthread.php?t=4439) and see what that tell you too.
2013 Candy Orange FLTRX
hometoast is offline
post #3 of 3 (permalink) Old 02-03-2015, 02:02 PM Thread Starter
G
G's Avatar
Thanks a ton!
G is offline
Tags
electrical , failure , speedo
Trans oil really, really hot! August Fluids and Lubricants 6 09-12-2014 05:44 PM
I really really like my RGU . . . . RonC26 *General Road Glide Discussions/Pictures 18 09-02-2014 06:55 PM
Sporadic knock at idle new tw-777 cam ChivoChavez321 Suspensions 6 10-26-2013 11:24 AM
Wtb-silver faced speedometer JPROADGLIDE Classifieds Archive (3 months old+) 3 02-15-2011 12:59 PM
I'm just being really really picky... BDMastiff *General Road Glide Discussions/Pictures 13 12-31-2010 11:11 PM
