Charging system issues - Road Glide Forums
post #1 of 17 (permalink) Old 02-04-2015, 08:36 AM Thread Starter
2012 RG Custom. Had the original voltage regulator changed out under the recall just after buying the bike. No problems for two years and 10k miles. Then, this past weekend, got check engine and battery light. Voltage gauge was showing 11 or 12. Rev'ed engine, the lights went out and the voltage jumped to 14.5 or so. Road the 40 or 50 miles home with no further issues.
I went ahead and picked up a new regulator, but tried to do some troubleshooting last night, before I installed it - mixed results.
- Testing the voltage across the battery terminals with the bike off was in spec, according to the service manual.
- Testing voltage across the battery terminals with the bike running was slightly low - 14.2 or so.
- I turned the bike off, unplugged the stator plug from the regulator to check output of the stator. When I cranked the bike, it ran like sh*t, so I just shut it back down. Is this normal?
- Confused, but still wanting to accomplish something, I went ahead and installed the new regulator. Afterwards, voltage across the battery terminals with the bike running actually dropped to 13.9 or so.
So, a few questions:
1) Does revving the engine and having the CE and Bat light go out and the volt meter return to normal mean anything?
2) Should the bike run really poorly with the stator unplugged from the regulator?
3) Any thoughts on why the output would read lower after installing the new regulator? Can I deduce anything from this?
4) Anyone have definitive numbers for a 2012 RG and a plain english guide on troubleshooting this stuff? I have the service manual and it doesn't cover it. I have found multiple postings on multiple forums, but the numbers are all over the place.
Any help will be greatly appreciated...
Gngraham is offline
post #2 of 17 (permalink) Old 02-04-2015, 10:11 AM
Had a similar issue with my bike (2013). It tested fine every time I tested. Took it to the delaer as every time I rode the voltage would drop low enough that the battery light would come on. It took about 30 minutes of riding for this to happen.
Dealer says "all is fine." I told them to ride it for 30 minutes and get back to me. Stator and regulator replaced under warranty. The pins between the two were burnt according to them although I don't believe a word any dealer says as they are all full of it.
Regardless, 13000 miles since replacement and all is still fine. Knock on wood.
Drew
HogPro is offline
post #3 of 17 (permalink) Old 02-04-2015, 11:08 AM
VR's are iffy. A VR that's just starting to go out will work most of the time. Check the Stator AC volts and the battery DC volts under load, if those # are good the VR is your calperate. Your battery shouldn't drop below 10 V while trying to start the bike. The book will have the Stator #s / rpm. Use a multimeter when checking not your in dash Guage.
post #4 of 17 (permalink) Old 02-04-2015, 11:14 AM
There is an exception to every rule as my bike always tested fine as per the manual.
Drew
HogPro is offline
post #5 of 17 (permalink) Old 02-04-2015, 11:23 AM
If the battery is bad and was not charged when you unplug the stator it may cause the bike to run poorly, this is because the battery is the only thing running the bike.
16 to 23 VAC is normal at the stator pins when the bike is running at 1000 rpms and it should put out 16 to 23 VAC for every 1000 rpm.
The voltage regulator should put out 14.3 to 14.7 at 3600 rpm at 75 F degrees.
My bike only puts out 16.9 volts at the stator pins when at 1000 rpm which is on the low end of the specs and the result is 14.0 VAC at the battery. I know it is a little low and the stator in my bike is getting to the end of its life but it still charges the battery and runs everything on my bike including the audio amp and the heated gloves and jacket.
You should be fine at 14.3 VAC, load test the battery and see if it is bad, if you have the battery on a tender take it off for a few days and see if it is holding a charge.
post #6 of 17 (permalink) Old 02-04-2015, 01:49 PM
Maybe I'm missing something, but what's wrong with 14.2 at the battery with the bike running, from all of my experience that's good. I also agree with if the battery is weak, the bike will run bad. The battery may show the proper voltage, but you should load test it to see if it's actually good.
post #7 of 17 (permalink) Old 02-04-2015, 02:47 PM Thread Starter
The initial test showed 14.2. After installing a new VR, it dropped to 13.9. I installed the new VR because I was seeing check engine and battery lights and the gauge dropping to 10 or 11.
I plan to load test the battery tonight...
Gngraham is offline
post #8 of 17 (permalink) Old 02-04-2015, 02:57 PM Thread Starter
Would the regulator not being grounded have the same effect, i.e. bike running poorly?
Can you tell me specifically, how to test this? I have a multimeter and I can figure out how o set it for VAC. Am I testing the stator pins at the end of the plug coming from the primary case? The end that plugs into the voltage regulator? Is it just a matter of sticking the leads into the holes in the stator plug?
This is the confusing part. With the initial regulator on the bike, it was putting out 14.2. After putting the new regulator on, it is at 13.9.
Thanks for the advice and help...
Gngraham is offline
post #9 of 17 (permalink) Old 02-04-2015, 03:43 PM
Doug06rg's Avatar
The last time that I had the battery light and the check engine light come on (quite a while ago), I replaced the HD garbage regulator with a Cycle Electric regulator.
I have not had an charging issue since!!!!!!
Doug06rg is offline
post #10 of 17 (permalink) Old 02-04-2015, 04:18 PM
Gray Beard
lundboy1's Avatar
Another issue however not as common on bikes is to have a couple of diodes fail (blow) in the rectifier which still show charging voltage but improper amperage this normally happens when a charging system is over worked i.e. Trying to charge a dead battery I try to explain to customers that alternators aren't battery chargers they need a good battery to operate efficiently and FYI I wouldn't panic about 13.9 to 14.7 when running
" wishin' my knees were in the breeze!!!"
lundboy1 is offline
Tags
battery light , charging , regulator , stator , voltage
charging issues? mjohnson68 Audio 4 01-10-2014 07:48 AM
iPhone 4S - Charging/Not Charging dinggus Audio 8 11-01-2013 09:25 AM
Charging Issues - Voltage Reg AGAIN?! TracknTail Troubleshooting for Road Glides 3 10-08-2013 12:04 AM
Possible Electrical Charging issues??? paco ritter Troubleshooting for Road Glides 5 10-05-2012 10:26 PM
Charging issues with 2011 RGU? bobzilla Road Glide Specific Discussions 12 07-20-2011 06:59 PM
