no power below 3k rpm engine issues - Road Glide Forums
post #1 of 6 (permalink) Old 02-16-2015, 01:11 PM Thread Starter
moosedrool's Avatar
my Road glides loosing power below 3k rpm.engines not making any noise
above 4k rpm rocker boxes chattering.with work schedule havent taking it apart yet.whondering if anyone has had similar problems going to tear bike apart next weekend.thinking cams ? havent done compresion leak down test yet
2007 FLTR
103 Big bore kit 10.5.1 comp,ported polished heads,intake,throttle body,feuling reaper 574 cams,screamin eagle cam chest,S&S air cleaner
moosedrool is offline
post #2 of 6 (permalink) Old 02-16-2015, 04:49 PM
Check for codes first. maybe in limp mode? Check your tuner to make sure that's running like it's supposed to be
post #3 of 6 (permalink) Old 02-16-2015, 04:58 PM Thread Starter
moosedrool's Avatar
thanks for the imfo ill check that
2007 FLTR
post #4 of 6 (permalink) Old 02-17-2015, 11:05 AM
If your bike is running over 1800 rpm then it is NOT in LIMP MODE. Limp mode shuts down the TCA so you only have enough power to pull the bike off the road to a safe location, simply put you have no throttle to speak of.
Do check for DTC,s first it is always a good place to start.
If there are no DTC,s and you have a aftermarket tuner try disconnecting the tuner and see if performance changes.
Do a compression check, and inspect your spark plugs and plug wires at the same time.
Check for intake leaks.
post #5 of 6 (permalink) Old 02-19-2015, 12:56 AM Thread Starter
moosedrool's Avatar
no codes tried to test ride yesterday.to check map and tune snapped drive belt
i dont have time to check bike.i towed it to performance shop that replaced back tire 2 weeks ago.there gonna check engine and tune compression test and
cams .ill post the final outcome soon .
2007 FLTR
post #6 of 6 (permalink) Old 03-08-2015, 10:58 AM
kyle31490's Avatar
How'd this turn out for You?
kyle31490 is offline
Cold start engine RPM on 107 engine 96349 Engine Related 3 11-07-2017 08:22 AM
Installed Duals, Engine vibration Below 2000 RPM bosshogg123 ECM/Fuel Management systems 2 09-12-2016 12:55 AM
3K chirp raker Engine Related 0 10-09-2013 08:41 PM
Rpm issues Roadrider81 Troubleshooting for Road Glides 12 05-15-2013 08:03 PM
3K miles, 1 week and the Shark ctmedic Road Trip Discussions/Stories/Pictures 10 10-20-2012 11:54 AM
