No Electrical whatsoever - Road Glide Forums
post #1 of 7 (permalink) Old 03-08-2015, 02:32 PM Thread Starter
Hi Guys and Girls,
I've put my 2010 RG back together after the build and I have NOTHING for electrical. I've checked all the typical suspects like fuses etc and all looks good. Battery is good and strong (the old one froze in the garage over the winter (yes it got cold up here)
I have no power anywhere, no gauges, headlight, stereo, horn etc.
When I rebuilt the only thing I didn't do is attach the ground wire to the top of the tree (like stock) because I put Pickard Raked tree on. I went directly to the handle bar mount. (pic of stock)
Any help would be appreciated - Electrical is not my strong suit.
The Crusher is offline
post #2 of 7 (permalink) Old 03-08-2015, 05:17 PM
BigB64's Avatar
That's a rubber bushing under washer! Potentially that could be the issue.
I would rather go to where the tank mounts to frame. Might be better off.
Sounds like you don't have ground/-
If you dont like what she is saying,Go for a ride
BigB64 is offline
post #3 of 7 (permalink) Old 03-08-2015, 05:18 PM
BigB64's Avatar
Your connected to ground at Fran in picture. Might be a dead battery from retailer!
I've had it happen with my chopper
Battery died bought another and that was dead
BigB64 is offline
post #4 of 7 (permalink) Old 03-08-2015, 05:22 PM
Road dawg's Avatar
Check for power at the battery with a multimeter, if okay check all your fuses.
Road dawg is offline
post #5 of 7 (permalink) Old 03-08-2015, 06:23 PM
FDR's RGC's Avatar
Main fuse. Got power at both ends! Is your ignition switch installed and working properly.
FDR's RGC is offline
post #6 of 7 (permalink) Old 03-08-2015, 08:05 PM
FrankieB's Avatar
Sounds like the maxi fuse is blown, ohm it out if it doesn't look bad.
06 RK
11 RGU
FrankieB is offline
post #7 of 7 (permalink) Old 03-08-2015, 08:56 PM Thread Starter
I will check but the fuse looks good. I was wondering about my ignition switch. It was a bitch to re-install but seems to be working fine now. How do i check it?
15 FLTRX Vivid Black............No Security & No ABS maddmoe Road Glide Builds-Document your builds HERE --NEW 135 08-28-2016 01:30 AM
NO OIL and no idiot light?? motodrummer Troubleshooting for Road Glides 16 06-18-2015 10:48 PM
Passenger floorboard mounts. No spring, no ball. Mounts only.40.00 shipped neverdone Sold 1 05-13-2014 07:57 PM
No 6th gear light, no cruise scsharp2260 ECM/Fuel Management systems 5 01-17-2013 03:14 PM
No Cruise, No Brake Lights , engine light and lots of codes DonJulio Troubleshooting for Road Glides 4 07-24-2011 06:02 PM
