Blown Battery Fuse - Road Glide Forums
post #1 of 6 (permalink) Old 03-28-2015, 04:27 PM Thread Starter
09Sharknose's Avatar
Blown Battery Fuse
Out on a ride and noticed the key light lit up on dash with no left turn signal.
Stopped at the store, came back out, radio works, FI works, but no odometer and bike won't start.
Checked fuses, blown battery fuse. Any ideas before I get robbed by the dealer? Thanks.
09Sharknose is offline
post #2 of 6 (permalink) Old 03-28-2015, 05:25 PM Thread Starter
Left rear turn signal not on when bike is on, but flashes when bike is turned off(security flash).
post #3 of 6 (permalink) Old 03-28-2015, 10:27 PM
I take it you tried just replacing the fuse , and it keeps popping. Any recent mods done lately ?
post #4 of 6 (permalink) Old 03-29-2015, 12:45 AM Thread Starter
Yeah I tried that. It turned out to be the HD run/brake/turn module under the seat. Once I noticed the rear left turn signal wasn't on when I turned on the bike, but flashed when the alarm was set, I knew it wasn't a power thing. I started at the rear taillight and worked my way up the wiring harness until I found the culprit. Threw it away, all is well. Thanks.
post #5 of 6 (permalink) Old 03-29-2015, 12:18 PM
I don't hear too much about the rear run/turn/brake module going bad but I guess it can happen. I been using the same HD module since 2008 and never had a issue with it.
post #6 of 6 (permalink) Old 03-29-2015, 01:17 PM Thread Starter
The module wasn't defective. My behind was! It was under my seat and I assume I shifted just right because it's busted on one side. If I buy another, it'll be the custom dynamics one that is integrated with their LED load equalizer. More functions, less crap under the seat to sit on.
2013 FLTRU Battery tender fuse riverdave1 *General Road Glide Discussions/Pictures 1 04-05-2018 04:36 AM
Legendair ride blown fuse killgorejohn Suspensions 0 10-25-2016 12:28 PM
2016 battery tender fuse location and size gdtanas Troubleshooting for Road Glides 1 05-05-2016 11:59 PM
Brand New CVO - Blown Motor Less than 15 miles PC PaiN *General Road Glide Discussions/Pictures 52 12-18-2011 01:28 AM
J&M 7.25 speaker problem - blown? CHAINSAW Audio 75 05-20-2011 06:44 AM
