Brake noise - Road Glide Forums
post #1 of 12 (permalink) Old 04-13-2015, 05:39 AM Thread Starter
emptyking's Avatar
Brake noise
Question for you all. Looking for some info on the "locust/cicada" noise I'm getting from my front brakes. Has anyone else had this issue? If so what were some on the fixes? My fiancé said shes always heard the noise but I haven't. And I worry about the smallest little noises lol. I've read that a few people have had it and went to the dealership and they say it's normal. Just trying to get some input from others. Thanks in advance.
emptyking is offline
post #2 of 12 (permalink) Old 04-13-2015, 07:26 AM
hometoast's Avatar
I swear I saw this exact same post with a couple replies not long ago. weird.
Does the noise only happen at "parking lot speed"?
2013 Candy Orange FLTRX
hometoast is offline
post #3 of 12 (permalink) Old 04-13-2015, 08:15 AM Thread Starter
emptyking's Avatar
No it happens usually above about 10 mph. And when I use the front brake it gets louder and when I release the brake it gets quieter. I'm not sure if it's always done it or not because I wasn't playing my radio yesterday when I noticed it. I think I may try and change the pads and see if that works.
post #4 of 12 (permalink) Old 04-13-2015, 08:28 AM
hometoast's Avatar
How many miles on those pads & rotors?
Any ugly grooves in the rotor?
post #5 of 12 (permalink) Old 04-13-2015, 09:13 AM Thread Starter
emptyking's Avatar
Just turned over 27000 miles and no noticeable groves
post #6 of 12 (permalink) Old 04-13-2015, 09:25 AM
It could be making noise because the pads may be glazed. Pull the pads and check the brakes. If the pads are good but have a glazed surface then you can use a fine sandpaper to scuff them up to remove the glaze. Also use some brake silicone lubricant on the backs of the pads and on the caliper and pins. Do not get any on the pad surface
post #7 of 12 (permalink) Old 04-13-2015, 10:22 AM
It's normal on my bikes', baggers with dual rotors. Questioned it back in the early nineties, others with a keen sense also notice it on new bikes not accustomed
reds4 is offline
post #8 of 12 (permalink) Old 04-13-2015, 11:16 AM
HellInABucket's Avatar
I have this too - had it across pad changes as well.
Question - do you have Agitators? Seems to me this showed up after I bought used Agitators that came with Harley floating rotors.
A couple dealers have test ridden it after service, they all say its normal.
But then again my engine could be missing a jug and they'd say its norma.
HellInABucket is offline
post #9 of 12 (permalink) Old 04-13-2015, 11:56 AM Thread Starter
emptyking's Avatar
That's what I'm hearing. I just called my local dealership and they said there is nothing I can do about it. Apparently in 08 they went to a new brake system and that's when they started hearing about it.
post #10 of 12 (permalink) Old 04-13-2015, 11:58 AM Thread Starter
emptyking's Avatar
Haha true that. They'll try to make anything up for a sale. That's why I love these forums. But my dealership is pretty good with helping out. But no I still have stock wheels.
Valve intake noise/cam overload noise Budd559 Engine Related 9 02-15-2016 06:23 AM
Brake noise Jas5489 Troubleshooting for Road Glides 13 08-26-2015 08:22 AM
need help with brake noise veetwin Troubleshooting for Road Glides 14 03-19-2014 10:43 PM
Brake noise, should I look into this Rgc13owner Troubleshooting for Road Glides 3 08-28-2013 12:54 PM
Front brake noise? SilverGhost Troubleshooting for Road Glides 9 06-27-2012 09:41 PM
