High RPM's, no acceleration - Road Glide Forums
post #1 of 10 (permalink) Old 04-17-2015, 11:31 AM Thread Starter
Unhappy High RPM's, no acceleration
The glide is not running smoothly! I was riding into work today and on the freeway, I gave it gas, no acceleration but went up to almost 5500rpms! I am running a thundermax system with performance machine air cleaner and Rhinehart 2:1 exhaust. Anyone have any ideas as to what this could be? I did stop for gas and when I tried to start the bike, the engine popped and a poof of black smoke came out of the air cleaner. It did start the second time around though, but still ran like ish. Any help would be appreciated, at least to get me home!
Desert Dweller is offline
post #2 of 10 (permalink) Old 04-17-2015, 11:54 AM
Sounds like the first problem is your clutch slipping.
post #3 of 10 (permalink) Old 04-17-2015, 12:15 PM
Bleachey's Avatar
+1. Have had it happen on my sons bike and several dirt bikes. Easy fix to replace the friction plates if an adjustment doesn't do the trick.
Bleachey is offline
post #4 of 10 (permalink) Old 04-17-2015, 12:27 PM Thread Starter
I did just replace the clutch lever. I may not have adjusted it correctly then. I'll start with that and go from there. Thanks for the info! I'll keep you posted and let you know how it goes!
post #5 of 10 (permalink) Old 04-17-2015, 04:04 PM
TRUBlue's Avatar
You may want to check Thundermax for software updates. You might be able to tune out the start up problem. Mine used to do the same thing until updated.
'12 FLTRU Big Blue Pearl
TRUBlue is offline
post #6 of 10 (permalink) Old 04-17-2015, 04:17 PM
I suggest you start with clutch adj. at basket.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #7 of 10 (permalink) Old 04-17-2015, 05:51 PM
RGKen's Avatar
+1^^^ But do this when it's cold. Don't try and adjust it right after a ride and it's hot.
2018 FLTRXS
RGKen is offline
post #8 of 10 (permalink) Old 04-17-2015, 07:56 PM
hook's Avatar
^What they said.
2011 RGU
hook is offline
post #9 of 10 (permalink) Old 04-17-2015, 10:58 PM Thread Starter
I adjusted the tension in the clutch cable and she's running smoothly again! Thanks for the info and I'm going to update the thundermax as well, see if she can run even smoother! Thanks gents!
post #10 of 10 (permalink) Old 04-17-2015, 11:00 PM Thread Starter
BTW, here's a link to a great video on youtube regarding adjustment of the clutch
https://www.youtube.com/watch?v=59oe54UWOWU
Weird acceleration issue TqAmsNy Troubleshooting for Road Glides 17 05-30-2016 09:36 PM
Rattling Noise at high RPM Bleachey Troubleshooting for Road Glides 5 02-29-2016 09:06 AM
21" wheel vibrates on hard acceleration Afacey *General Road Glide Discussions/Pictures 22 09-24-2015 01:13 PM
Lifter Acceleration BlackDangerous Engine Related 13 02-02-2012 10:25 PM
Poor Acceleration 2BWILD Troubleshooting for Road Glides 17 08-19-2010 05:09 PM
