problems filling fuel 2015 RGS - Road Glide Forums
post #1 of 17 (permalink) Old 04-20-2015, 09:43 AM Thread Starter
danfor's Avatar
Stupid question!! Filling the gas on my 2015 Road Glide Special is a pta!!!
I have tried every different angle, filling slowly but it still splashes ALL over the place!!
Is anyone else having this problem & more importantly does anyone have a good suggestion??
I heard some where that there is an anti-siphon deal in the tank, I'm wondering if this has something to do with it??
2015 Road Glide Special in denim black, 4" Rinehart true duals, Thunder Max tuner, Arlen Ness Deep Cut air cleaner & grips, 4.5" extended saddlebags, rear fender extension, 12" KST apes, Focal Focal KRC & AC speakers, Arc Audio Moto 600.4 amp, custom pin striping, Kuryakyn horn cover, over 40 powder coated parts and counting. More to come!
danfor is offline
post #2 of 17 (permalink) Old 04-20-2015, 10:00 AM
Bleachey's Avatar
I have the same issue with my 2011, not sure what is different about the new ones. I always grab several paper towels and cover the gap. I use several because I don't want it soaking through and getting on my hands.
Bleachey is online now
post #3 of 17 (permalink) Old 04-20-2015, 11:15 AM
TLKurtz's Avatar
Send a message via Skype™ to TLKurtz
Not sure why you'd be having issues. Unless I'm careless when refueling, I've never had an issue with my 2012 that I traded in or the new 2015.
-TLKurtz (Mr. Wizard) - Blackhorse Cavalry Nomads VMG member (2/11 CAV - East/West German Border)
2015 RGS - Vivid Black and loads of fun.
Reside in Vegas. I keep cold beer in the fridge for all visitors.
TLKurtz is offline
post #4 of 17 (permalink) Old 04-20-2015, 01:36 PM
My '09 is a PITA compared to any other bike that I have ever put fuel in!
'Trying every way that I can think of, parking the bike with the pump on the left seems to work the best for me...
HeatWave is offline
post #5 of 17 (permalink) Old 04-20-2015, 01:37 PM
top off issue
Yes, I have a 2010 and getting that last 1/2 or more is a pain.
I usually just shake and tilt several times to get the air pocket out.
The next time I have the filler off/out I'll drill breathing holes in the top front.
2010 FLTRX,103 Stage 2,FullSac 2-1-2, black ceramic CB/Intercom, Power Vision
websterdan is offline
post #6 of 17 (permalink) Old 04-20-2015, 02:21 PM
I fill my 2011 until the nozzle clicks off, then pull it out a bit & then click the nozzle until it's completely full, but some nozzles work better than others & you will get some splashes. Good luck.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #7 of 17 (permalink) Old 04-20-2015, 02:29 PM
Definitely a problem on the 2015 RG. You just have to adjust the angle and go slow with the gas. There are some threads on modifying the internals to solve this problem on the HD forums but it looked like more of a pita then messing with the fuel. I also carry some detailing spray and a microfiber cloth to clean up what I spill.
Bassani Road Rage 2:1
204 Cams
Screaminz is offline
post #8 of 17 (permalink) Old 04-20-2015, 02:36 PM
This should kick it off
http://www.hdforums.com/forum/new-ru...-gas-tank.html
204 Cams
post #9 of 17 (permalink) Old 04-21-2015, 09:28 AM Thread Starter
danfor's Avatar
thanks for the info Screaminz, I'll check it out!
danfor is offline
post #10 of 17 (permalink) Old 04-21-2015, 12:11 PM
Speedie's Avatar
Interesting. I see no difference between my '15 and '12 RGs for fueling. Do you guys live in a state where you have the emissions collar surrounding the nozzle?
2019 Road Glide Special
Detachable Trunk : Detachable Passenger Back Rest
Rinehart Exhaust : J&M 330W Rokker Amp and Speakers
Speedie is offline
Tags
fuel filling , gas
Runs poorly after filling up with gas PAhumbug Troubleshooting for Road Glides 9 07-09-2014 05:34 PM
Filling King Tour Pak Backrest Holes 93-331-29psi Do-IT-Yourself 4 05-26-2014 11:36 AM
Filling Tour Pak Holes gfyoung3 Paint & Bodywork Section 3 02-15-2014 12:40 PM
Filling Holes on Tour-Pak from Antenna Mount hoser6868 *General Road Glide Discussions/Pictures 6 02-23-2012 11:21 PM
Filling hole for mirror. fosterp Controls & Handlebars 8 01-28-2012 11:56 AM
