No Turn/Brake lamps or Cruise - Road Glide Forums
post #1 of 7 (permalink) Old 04-22-2015, 10:13 AM Thread Starter
407Driver's Avatar
Anyone had this problem? May save me some time if one wants to share.
Thanks
2013 FLTRX. Denim Black
407Driver is offline
post #2 of 7 (permalink) Old 04-22-2015, 10:18 AM
RGKen's Avatar
Did you change grips or have the controls off the handlebars? If so you may have broken the front brake switch.
2018 FLTRXS
RGKen is offline
post #3 of 7 (permalink) Old 04-22-2015, 10:22 AM
HellInABucket's Avatar
Also, while its running, check to see if the security key light stays on.
If so, you have an electrical problem somewhere, likely a pinched wire, and most likely to be one of your front turn signals if you've ever had the outer fairing off.
Also, it is possible that the 2 problems are separate issues.
HellInABucket is online now
post #4 of 7 (permalink) Old 04-22-2015, 10:23 AM Thread Starter
407Driver's Avatar
New Bars with wires run through almost a year ago. Hoping like hell it isn't chaffing. All three things associated with right side controls though.......
post #5 of 7 (permalink) Old 04-22-2015, 10:24 AM
In most cases one of the brake switches is the problem. There was a recall on the rear brake switch on the newer RGs. Brake light switches will affect cruise control function.
Sometimes the Run/Turn/Stop module can go bad so check that if you have one on the bike but it shouldn't affect the cruise.
post #6 of 7 (permalink) Old 04-25-2015, 11:48 AM Thread Starter
407Driver's Avatar
So riddle me this Batman. The accessory fuse was blown! I have nothing wired to the accessory harness.
post #7 of 7 (permalink) Old 04-25-2015, 02:06 PM
FDR's RGC's Avatar
If it was blown, something else is on it.
FDR's RGC is online now
WTS; HD Keystone LED Run/Brake/Turn Lamps paid4c4 Parts for Sale 2 04-26-2018 08:41 PM
red cruise light, no cruise piggs Troubleshooting for Road Glides 1 05-08-2014 06:47 PM
No 6th gear light, no cruise scsharp2260 ECM/Fuel Management systems 5 01-17-2013 03:14 PM
no turn signals, brake lights, or power to cruise MoRob Troubleshooting for Road Glides 4 07-02-2012 10:23 PM
No Cruise, No Brake Lights , engine light and lots of codes DonJulio Troubleshooting for Road Glides 4 07-24-2011 06:02 PM
