Loose mirror - Road Glide Forums
post #1 of 9 (permalink) Old 04-26-2015, 03:48 PM Thread Starter
Loose mirror
Have stock mirrors on a 2005 RG. The right mirror won't stay in place with the engine vibration. After adjusting, it always drifts down after a couple minutes of riding.
The connection between the stem and the mirror is a ball. I don't see anyway to tighten it down.
Any ideas before i start searching for a new mirror purchase?
Thanks!
Phil
Phil-AK is offline
post #2 of 9 (permalink) Old 04-26-2015, 03:51 PM
Gray Beard
lundboy1's Avatar
Try some green lock tight in the joint
" wishin' my knees were in the breeze!!!"
lundboy1 is offline
post #3 of 9 (permalink) Old 04-26-2015, 04:45 PM
FDR's RGC's Avatar
Heat the mirror glass and remove it. You'll see the plate that holds the ball tight against housing, a couple raps between the ball and mounting spots with a hammer and blunt chisel will tighten ball up. Clear silicone will hold the mirror back in. Just did one for a friend's sportster.
FDR's RGC is offline
post #4 of 9 (permalink) Old 04-26-2015, 05:16 PM
BDMastiff's Avatar
I have the same problem with my 96 Fatboy. I finally spent $34.95 and bought a brand new new set from HD. In my case the hassle of trying to repair it over and over wasn't worth the effort.
1996 Fatboy
BDMastiff is offline
post #5 of 9 (permalink) Old 04-26-2015, 06:35 PM
check the back of the mirror there should be 2 screws there tighten those that pulls the plate tighter onto the ball to prevent movement
Eagle is offline
post #6 of 9 (permalink) Old 04-26-2015, 07:30 PM
HellInABucket's Avatar
Get new mirrors, the stock ones are homely, and new ones aren that expensive.
HellInABucket is online now
post #7 of 9 (permalink) Old 04-26-2015, 07:45 PM
FDR's RGC's Avatar
The old ones had the screws,on evos was the last time I saw those.
post #8 of 9 (permalink) Old 04-26-2015, 08:46 PM
Done that long go, buy the extended mirrors ( n0 more shoulder checks) and lightly crank on the acorn nut, less than a scrip for other extenters
reds4 is offline
post #9 of 9 (permalink) Old 04-27-2015, 01:42 AM Thread Starter
Thanks everyone for the advice.
Phil-AK is offline
Aeroview Mirror Cowling "NEW" Bill H Sold 8 05-06-2012 09:14 AM
Filling hole for mirror. fosterp Controls & Handlebars 8 01-28-2012 11:56 AM
HD Mirror extensions Big_gary Classifieds Archive (3 months old+) 1 03-01-2011 08:19 PM
Rear View Mirror FF helmet DreamRider Helmets 2 02-21-2011 06:47 PM
CVO 2009 mirror part # abone Controls & Handlebars 8 02-01-2011 07:43 PM
