2005 tachometer issues - Road Glide Forums
post #1 of 1 (permalink) Old 04-28-2015, 08:09 PM Thread Starter
My tach is acting as follows, when I turn on the ignition switch (without engine running), the tach makes a ticking noise and jumps from 0 to 600 or 700 rpm and stays there even when I turn off ignition switch. If I turn the switch on and off, the tach needle keeps climbing and stays in the last position. I pulled the maxi fuse, the needle fell back to zero, started the bike and it was ok. Took the bike for a ride, the problem came back, needle came to rest at 6 o'clock position on tach. Pulled the maxi fuse, but needle wouldn't return to zero.
Anyone experience this before or have any suggestions?Thanks
Xinthrax is offline
Gauges, indicators, speedometer, tachometer all quit working Hog Happy Active Military and Veteran's group 5 10-12-2016 06:32 PM
WTB Speedometer/Tachometer fairing cover Bruckus Wanted! (Buy or Trade) 3 12-25-2014 04:33 PM
Tachometer Issues willbo22 Troubleshooting for Road Glides 1 07-06-2014 08:36 PM
Speedo and Tachometer Replacing Leds BLACKHAWK Troubleshooting for Road Glides 6 01-24-2012 07:56 PM
large tachometer?? FUGLY *General Road Glide Discussions/Pictures 0 09-15-2010 01:26 PM
