Battery warning light - Road Glide Forums
post #1 of 22 (permalink) Old 05-01-2015, 07:08 PM Thread Starter
Sparky's Avatar
So on the way home from work today, the battery and engine warning lights come on and voltage gauge drops to 11 volts or so. Bike continues to run fine. I stop at a local battery shop and the guy says it is most likely related to the charging system. Bike starts up fine and everything is normal for the 20 mile ride home. Any ideas? Thanks.
2012 BBP RGC - KW Super Saver slip ons,HD stage 1 A/C,Cobra tuner, 10" Windvest, Sanchos wings, 11" Santees
Sparky is offline
post #2 of 22 (permalink) Old 05-01-2015, 07:35 PM
Voltage regulator is probably on its way out. They're hard to test when they first start going bad because they're intermittent. Test battery and stator, if they're good , you know its probably the VR.
post #3 of 22 (permalink) Old 05-01-2015, 07:47 PM
100edition's Avatar
If it's the regulator you will smell it soon. Distinct electronic burn smell. Mine did the same on a long trip. 50 miles or so after light came on it went in limp mode. I was in the middle of nowhere. Only time bike was on a trailer.
100edition is offline
post #4 of 22 (permalink) Old 05-01-2015, 09:02 PM
GlideShark's Avatar
Same thing happened to me last week. Both my stator and VR were replaced.
GlideShark is offline
post #5 of 22 (permalink) Old 05-01-2015, 09:08 PM
Bandman's Avatar
Glideshark, was it under warranty or is this going to be on my dime?
Bandman is offline
post #6 of 22 (permalink) Old 05-02-2015, 01:36 AM
FDR's RGC's Avatar
If your bike is under warranty,then yes.
FDR's RGC is offline
post #7 of 22 (permalink) Old 05-02-2015, 08:34 AM
Bandman's Avatar
Excellent, I was afraid that might be something they would say was normal wear and tear and sorry, we don't cover that. Thanks!
Bandman is offline
post #8 of 22 (permalink) Old 05-02-2015, 10:09 AM
It sounds like the Voltage Regulator is starting to have problems.
The 2012 models had a recall on the VR so check the dealer and see if your bike is on the recall list.
post #9 of 22 (permalink) Old 05-02-2015, 10:32 AM
Bandman's Avatar
I'm not, unless they expanded the list. I will still try.
Bandman is offline
post #10 of 22 (permalink) Old 05-02-2015, 01:48 PM
Wood's Avatar
The VR's are prone to fail; my 2010 did. Harley didn't design them correctly or they have poor quality from their supplier.
Wood is offline
Service Engine Light, Battery Light and 11 Volts, 13 FLTRX shane_huskey Troubleshooting for Road Glides 6 02-17-2018 05:16 PM
Security warning light? HD2012CVO Tech Area 5 09-10-2016 07:46 PM
WARNING Clutch problem WARNING beatlesfab4fan *General Road Glide Discussions/Pictures 16 12-28-2015 01:08 PM
Check Engine Light and Battery Light following Jackpot 2-1-2 install PearlBlueUltra Troubleshooting for Road Glides 9 06-15-2014 04:59 PM
New Bike - Engine & Battery Light pscan5150 Troubleshooting for Road Glides 15 06-08-2012 06:02 PM
