2011 RGU No Start Need some Help - Road Glide Forums
post #1 of 8 (permalink) Old 05-12-2015, 12:15 PM Thread Starter
Hey folks I've got a 2011 RGU and I cannot get I to turn over. I've had the battery on trickle for the last 3 weeks. I appear to have good power as the radio and all systems power up but when I push the start button I get nothing.
I would rather not take it to the dealer so I am asking for some help here, please.
KClark is offline
post #2 of 8 (permalink) Old 05-12-2015, 12:48 PM
JacktheBagger's Avatar
All that stuff will power up sometimes with a dead battery . Do you have a multimeter ?
Should have close to 13v across the terminals.Three weeks and nothing is very likely the battery.
JtB
2011 Ultra
JacktheBagger is offline
post #3 of 8 (permalink) Old 05-12-2015, 12:56 PM
Shemp's Avatar
Make sure your kill switch is in the run position. Happens
2011 RGU Merlot/Sunglo, Daymakers, 13" Madstad dark grey windshield, LED tourpac lights, SE RT/SE AC, Bassani Road Rage 2/1 pipes, Wild 1 10" mini apes, Street Glide fascia.
Miles of twisting mountain roads with no guardrails!
Shemp is offline
post #4 of 8 (permalink) Old 05-12-2015, 01:23 PM
nsbohall's Avatar
+1 on this if you're getting absolutely nothing when trying to start. Make sure the key fob battery is good too.
2013 FLTRU, S&S Power Tune Duals, Supertrapp Stouts, Andrews 48's, AN Big Sucker, Direct Link, Fuel Moto LED's, Custom Dynamics, 14.5 Madstad, 14" Carlini's, Legends AXEO and Revo A's.
nsbohall is offline
post #5 of 8 (permalink) Old 05-12-2015, 01:57 PM Thread Starter
Thank you Kill switch is on I will try the multimeter and change the remote batteries.
KClark is offline
post #6 of 8 (permalink) Old 05-13-2015, 09:33 PM
Sam07's Avatar
Original battery? Get it load tested at an auto parts store. Amazon sells the same Harley battery made by deka for 109 plus free shipping.
Big Crank ETX30L Battery https://www.amazon.com/dp/B0007VU48K..._nR.uvb1EDQFH8
2013 RGC
Sam07 is offline
post #7 of 8 (permalink) Old 05-14-2015, 11:12 AM
Check the small wire at the back of the starter, if that has a bad connection the starter will be dead as a door nail, no click ,clunk just silence. If that wire is good then check your starter relay in the fuse block.
You should also check all the other wire connections at the starter.
post #8 of 8 (permalink) Old 05-14-2015, 03:30 PM
+1 on the relay, if daring you could try a jumper cable direct to the starter lug, if she spins then it is the control side of the starter button, kill switch or relay.
BTW make sure the bike is really in neutral, don't ask me how I know to double check it before using a jumper cable.
1982 FLT Virgin unmolested barn find.
1983 FXDG 80th Anniversary AKA Willie G Disc Glide, 10.5 to 1, Andrews B grind, 2002 Fat boy carb, Barnett Clutch, drag pipes.
2003 FLTSCI Black and Silver converted with Motor Trike Kit plus HD tour pak, 88 inch, HD 204 Cam, Vance & Hines mid shots.
AzHogRider is offline
Crank no start, crank start Sam07 Troubleshooting for Road Glides 10 05-15-2018 09:03 AM
Need help - need a tuner with some skills in SW Mich Captain America Dyno Results 1 06-03-2017 12:51 AM
2011 RGU Intermittent No Start RGJim Controls & Handlebars 9 01-17-2017 07:33 AM
No start, Help! jupiter Troubleshooting for Road Glides 2 04-02-2013 12:29 PM
Need help Bike won't start cwdouble Road Glide Specific Discussions 10 02-20-2012 12:07 PM
