b1121 left turn output open - Road Glide Forums
post #1 of 6 (permalink) Old 05-17-2015, 02:58 PM Thread Starter
Hi All,
Can any one point me in the right direction. what does b1121 left turn output open mean? My left turn signals are not working, checked bulbs and fuses, no problem found there.
mdenari is offline
post #2 of 6 (permalink) Old 05-17-2015, 04:09 PM
cobra206's Avatar
U could have a pinched wire somewhere causing them to ground out
cobra206 is offline
post #3 of 6 (permalink) Old 05-17-2015, 04:33 PM
arkieglide's Avatar
If you have had the fairing off, there may have been a wire pinched or broken where the turn signal wires feed thru the fairing mount.
2011 RG Ultra Brilliant Silver Pearl
arkieglide is offline
post #4 of 6 (permalink) Old 05-17-2015, 04:41 PM
09Sharknose's Avatar
Very common problem. Start here if no obvious solutions.
09Sharknose is offline
post #5 of 6 (permalink) Old 05-17-2015, 05:21 PM Thread Starter
that is exaclty what happened, loosened the fairing, reattached the turn signal, and VOila!!
Never would have figure out without your guidance!! Thanks a lot!
mdenari is offline
post #6 of 6 (permalink) Old 05-17-2015, 05:44 PM
Ohiobellboy's Avatar
Now you need to check those wires real good if you didn't already. I'm sure you have some insulation that's rubbed off.
A.K.A OBB
Ohiobellboy is offline
Going left..... Way left! DarbinCo Troubleshooting for Road Glides 13 09-20-2012 11:16 PM
Left turn signal richrabb *General Road Glide Discussions/Pictures 3 12-14-2011 08:45 AM
left turn signal rdbateman Troubleshooting for Road Glides 14 06-22-2011 06:45 PM
