Acc switch and cig lighter dead - Road Glide Forums
post #1 of 9 (permalink) Old 05-20-2015, 06:08 AM Thread Starter
BigB64's Avatar
I have an issue with Acc switch not working and my cig lighter is dead?
Fuse still good, I haven't dug to deep but any ideas?
If you dont like what she is saying,Go for a ride
BigB64 is offline
post #2 of 9 (permalink) Old 05-20-2015, 10:57 AM
DED HD's Avatar
Im sure someone here will help ya figure it out.
What mods have you recently done?
Did you turn the ignition switch on?
possibilities-
Sometimes the Cig lighter is wired in reverse from factory.
hot wire on back of cig lighter came un plugged?
'10 Red Custom:
DED HD is offline
post #3 of 9 (permalink) Old 05-20-2015, 11:30 AM
PGR
PGR's Avatar
How do you know the fuse is good? If you used a meter, or just a visual inspection, that is sometimes deceptive. Stick another fuse in and try it.
If memory serves... the ACC fuse is 2nd from the left in the top row, and is 15 amp.
Ron..........................
PGR is offline
post #4 of 9 (permalink) Old 05-20-2015, 11:33 AM Thread Starter
BigB64's Avatar
I used my meter, I just installed bars, day makers, amps speakers cams, wheels, powder coated everything, oops I'm bragging but yes I've been in the fairing a bunch!
BigB64 is offline
post #5 of 9 (permalink) Old 05-20-2015, 11:37 AM Thread Starter
BigB64's Avatar
yes it is and I rang it out with meter. I added an amp and jumped of the cig lighter and I don't even think the cig lighter has worked in a while. I tried to plug in phone charger before and nothing. last night I installed Iron Aces mount and that's when when I discovered I had no power to acc switch. I don't even get a light on switch.
BigB64 is offline
post #6 of 9 (permalink) Old 05-20-2015, 12:04 PM
DED HD's Avatar
well the ACC switch should light up if the fuse is good.
I don't have my manual in front of me, but there are 2 fuses in the circuit. I think the acc fuse covers the cig lighter side of the circuit and the P&A fuse covers the rocker switch side of the circuit
Check the P&A fuse and the ACC fuse again.
'10 Red Custom:
DED HD is offline
post #7 of 9 (permalink) Old 05-20-2015, 01:02 PM Thread Starter
BigB64's Avatar
I'll try tonight
Thanks
BigB64 is offline
post #8 of 9 (permalink) Old 05-20-2015, 10:41 PM Thread Starter
BigB64's Avatar
P&A fuse was bad/ didn't even check that! Thanks
BigB64 is offline
post #9 of 9 (permalink) Old 05-22-2015, 05:06 PM
DED HD's Avatar
glad you got it fixed!
'10 Red Custom:
DED HD is offline
Cig lighter use? Boomer13 Equipment-RG 31 04-01-2012 10:45 AM
Road lide and cig lighter CPY84 *General Road Glide Discussions/Pictures 15 08-21-2011 09:39 AM
Lost Cig lighter sportyguy69 *General Road Glide Discussions/Pictures 15 06-30-2011 12:53 PM
Cig Lighter no worky, could be that... Wooden Nickel Road Glide Specific Discussions 0 06-25-2011 09:49 PM
Which fuse for the cig lighter... jupiter Troubleshooting for Road Glides 6 04-08-2011 10:38 AM
