Battery going dead - Road Glide Forums
post #1 of 9 (permalink) Old 05-22-2015, 05:59 PM Thread Starter
LittleMoe's Avatar
Battery going dead
Ok, i have a 2006 Glide, bought a new MILWAUKEE TWIN MTX30L BATTERY from J&P last may, and now i am having issues with the battery draining after a few days, or a cold night. My charging system checks out fine, 14.0 V at idle, did a parasitic draw test, turned out good, 2.07 mA, load test on the battery turned out fine. I am running out of ideas. Any suggestions??? Am i having issues because it is a non Harley battery?? Do i need to run a ground wire from the battery directy to the frame??? All help is very appreciated !!!
'06 FLTRI/Gel seat/Rheinhart exhaust/PCIII USB/Wind Vest 16" sheild/Progressive Monotubes/WAAAY too much chrome Willie G chrome... wanna trade for blacked out parts?
LittleMoe is offline
post #2 of 9 (permalink) Old 05-22-2015, 07:07 PM
There should already be a ground to frame from the battery but I wouldn't think that would be your problem.
I am assuming that all the battery connections are clean and tight so I would guess that the battery is just going bad for some reason. Sometimes some batteries just don't last as long as others, try taking the battery down and have it load tested.
If the battery is the problem you should check out http://www.batteymart.com they have great prices on batteries.
post #3 of 9 (permalink) Old 05-22-2015, 07:40 PM
Like Mark said, have the battery load checked. If that checks out good, check all connections are tight and clean. If thats all good, look toward the voltage regulator.
post #4 of 9 (permalink) Old 05-22-2015, 07:44 PM
clean up the ground point. worked for me after all else failed.
Jayray is offline
post #5 of 9 (permalink) Old 05-22-2015, 10:48 PM Thread Starter
LittleMoe's Avatar
Thanks for the replys !!! As i stated in the original post, i did have it load tested, and it was fine. I am pullin 14 V at idle, what should it go up in regards to engine RPM?
post #6 of 9 (permalink) Old 05-22-2015, 11:03 PM
RGKen's Avatar
I had one of my batteries load tested and it showed 14v but ended up having a bad cell. Put a new battery in and everything was good.
2018 FLTRXS
RGKen is offline
post #7 of 9 (permalink) Old 05-23-2015, 10:05 AM
Make sure the connections for the battery are clean and tight. I had one where the ground cable loosened up at the frame mounting point and it caused all kinds of havoc.
How long between rides? More than a week it should have a tender, batteries can and do discharge just sitting there. I like the NOCO tenders I have here for about half the price of an official HD one.
http://www.geniuschargers.com/?ADV=L...YNfxiF7.eMiCeQ
They are all over eBay. I think I have the G1100 models for the bikes.
1982 FLT Virgin unmolested barn find.
1983 FXDG 80th Anniversary AKA Willie G Disc Glide, 10.5 to 1, Andrews B grind, 2002 Fat boy carb, Barnett Clutch, drag pipes.
2003 FLTSCI Black and Silver converted with Motor Trike Kit plus HD tour pak, 88 inch, HD 204 Cam, Vance & Hines mid shots.
AzHogRider is offline
post #8 of 9 (permalink) Old 05-23-2015, 10:29 AM
I never used a battery tender on my bike and I never had any problems starting the bike even if it sat for months with the security on. If your battery can't last a few days before going dead then there is a problem with the battery.
You will have parasitic draw on a battery anyways from the clock and security system but that draw is minimal and it shouldn't drain a battery in just a few days.
14 volts at a idle is good and your charging system is working fine but you should keep a eye on the voltmeter for voltage drops or spikes which would indicate a problem.
post #9 of 9 (permalink) Old 05-23-2015, 10:33 AM Thread Starter
LittleMoe's Avatar
In the last few weeks, it sat no longer then two days at a time, and i do have a tender for it otherwise.
Dead Battery? BigWaterJim Troubleshooting for Road Glides 6 07-17-2015 03:35 AM
Battery dead after amp install infernomd Audio 12 09-04-2013 03:08 PM
Dead fob battery bambamortiz Tech Area 20 05-30-2013 10:42 PM
Consequences of long dead battery? carcass *General Road Glide Discussions/Pictures 7 01-08-2013 09:48 PM
Now battery is dead a month after installing J&M amp DED HD Audio 4 06-30-2011 02:28 PM
