15 rgs lights - Road Glide Forums
post #1 of 9 (permalink) Old 05-30-2015, 12:24 AM Thread Starter
15 rgs lights
Need some help. 2015 RGS with 5100 miles. Took apart the front and rear blinker/running light assemblis for powder coat. Put everything back together but now am having issues. If my front signals are unplugged, my rear assembly has one light that works correctly and one that is on bright (like when you hit the brake) and doesn't blink. If I plug my front signals in, I get brakes, signals, but no running lights front or back. Any ideas?
Acro915 is offline
post #2 of 9 (permalink) Old 05-30-2015, 09:22 AM
I would start with checking all wiring making sure they are in the correct spot and plugged in securely and make sure the bulbs are all good .
Eagle is offline
post #3 of 9 (permalink) Old 06-03-2015, 06:55 PM Thread Starter
checked the bulbs and from what I can see, the wiring looks good. position of the wires should not make any difference. It's a simple neg ground system with a dual filiament bulb. I've checked ALL fuses (lol) checked my connectors, checked my wires for damage, and I'm not coming up with anything. At this point I'm not really sure what else I could look for. I'm really not wanting to take it in because I doubt I'll be able to convince them to cover it under warranty lol.
Acro915 is offline
post #4 of 9 (permalink) Old 06-03-2015, 09:53 PM
the position of the wires will matter , one filiment of the bulb will be brighter for your turn in the front and brake turn in the rear if you put the wrong wire in the wrong position it will light the incorrect part of the bulb and perhaps confuse the system with improper resistance I hear the new canbus system is really picky
Eagle is offline
post #5 of 9 (permalink) Old 06-04-2015, 07:11 AM
Can bus communicates by seeing changes in resistance. Purple wire should go to the "tab" on the bulb base. Here is a pic I took during tear down.
mray81 is offline
post #6 of 9 (permalink) Old 06-04-2015, 06:12 PM Thread Starter
Damn! I didn't think about the resistance! I feel like an idiot now. My electrician mindset kicked in and blocked out the computer aspect! Looks like I'll be taking apart all my lights again lol. God I hope this is the solution to my problem. Thank you for the Pic and the help. I'll be checking (and correcting as needed) this tomorrow. Hopefully I'll be able to get on and Shout out praises for all the help fixing my problem.
Acro915 is offline
post #7 of 9 (permalink) Old 06-06-2015, 03:02 AM Thread Starter
Eagle and Mray....Thank you. Your insight has fixed my problem. I guess I'll have to stop thinking of the bike as regular electrical system and more like a computer. Thank you again so much. I am sure you just saved me a good few bucks!
Acro915 is offline
post #8 of 9 (permalink) Old 06-08-2015, 11:37 AM
Glad it worked out for you.
mray81 is offline
post #9 of 9 (permalink) Old 06-08-2015, 04:51 PM
glad we could help wiring can be a pain and sometimes we all over think things
Eagle is offline
2015 RGS - no lights or activity in gauges glacieredlightning Troubleshooting for Road Glides 40 11-27-2018 09:42 AM
Rear Rnning lights on 2015 RGS not working.Cant find Fuse for lights. Help Jerseycyclone21 *General Road Glide Discussions/Pictures 3 02-20-2017 08:24 AM
No Turn Signals, Running Lights, or Brake lights on 15 FLTRXS warbird458 Lighting 5 07-12-2016 08:02 AM
15 RGS Lights flickering jp374 Lighting 4 09-20-2015 10:43 AM
Flush Mounting Tail Lights / Brake Lights gbourdon *General Road Glide Discussions/Pictures 5 09-29-2011 12:55 PM
