transmission question. - Road Glide Forums
post #1 of 12 (permalink) Old 05-31-2015, 02:02 PM Thread Starter
and yes I hit the search feature first
so my 2011 has 19k on her. it seems the tranny is getting louder.
appears to be running fine, shifting fine but at speeds after running a while, the tranny gets louder and almost like a loud popping/clicking noise.
has standard oil from the dealer in it and I have the redline sitting on the shelf as 20k is time to change it.warranty runs out in august.
is it normal for it to get louder as the fluid is nearing its end?
I am asking now before taking it to the dealer for maybe someone has had this issue in the past.
2011 RG ULTRA.
I RIDE. I FISH. HENCE THE THE ROD HOLDERS MOUNTED.
NOTHING LIKE DOING BOTH WHAT I ENJOY IN THE SAME DAY.
CPY84 is offline
post #2 of 12 (permalink) Old 05-31-2015, 03:18 PM
If it's under warranty, take it in and let them check it out. Keep the paper work for your records.
post #3 of 12 (permalink) Old 05-31-2015, 03:40 PM
Don't wait, take it in.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #4 of 12 (permalink) Old 05-31-2015, 04:18 PM
JacktheBagger's Avatar
no it's not normal
and I wouldn't wait till 20K to change it , just changed mine with 15K on it and it looked awful ..
I change my primary and trans every motor change , with that one exception , oil is cheep
JtB
2011 Ultra
JacktheBagger is offline
post #5 of 12 (permalink) Old 05-31-2015, 07:21 PM
I would take it in and have the dealer change the trans fluid that way the tech can see how much metal shavings are on the drain plug and if any chunks of metal come out. If you do the oil change before you take it in there may not be any metal in the oil when the tech drains it.
Should of been using gear lube instead of motor oil in that trans.
post #6 of 12 (permalink) Old 06-03-2015, 04:40 PM Thread Starter
dropping it off at the dealer tonight, in between rain drops.
2011 RG ULTRA.
CPY84 is offline
post #7 of 12 (permalink) Old 06-05-2015, 08:22 PM Thread Starter
well got the call from the stealer today. they rode it for a total of 50 miles and everything sounds fine. no issues. great. now you owe me 50.00 for your deductible plus 47.80 for 1/2 hour labor and 8.00 for shop stuff.
fortunately the owner of the dealer was there so I took the receipt to her for an explanation as I was told they only thing they did was ride it.
we walked back to the service guy and she asked why the 47.50 and 8.00.
well we have to pay the tech for his time and he had to wash his hands before getting on the bike and he wiped it down when he was done.
I paid the deductible and left.
tomorrow the redline and mobil 1 will be put in.
on another note the 2015 rg cvo is sweet looking at 40.524.00
2011 RG ULTRA.
CPY84 is offline
post #8 of 12 (permalink) Old 06-05-2015, 10:15 PM
Glad to hear that the tech thinks it is OK! You should consider using 75w90 or 75w140 gear lube in the transmission. I use 75w140 in the summer.
post #9 of 12 (permalink) Old 06-05-2015, 11:15 PM
idahointrudr's Avatar
Its unfortunate but the techs at my local Harley shop all having hearing problems? Might be part of the requirement?
You will be surprised what good oil will do,
2013 BBP TTS Tuner, Andrews 222 cams. Black Heritage bars, Dragos H Pipe, Madstad shield, Sanchos Wings
idahointrudr is offline
post #10 of 12 (permalink) Old 06-06-2015, 09:21 AM
If your putting in Red line shock proof , your going to be surprised at how it alone, quiets the gears .
Transmission Bearing Failure Question Stoic Joker Do-IT-Yourself 20 12-06-2018 12:06 PM
Primary and transmission fluid question ? Road dawg Tech Area 14 06-22-2013 07:49 AM
Transmission problem? staush Troubleshooting for Road Glides 6 05-16-2011 09:31 AM
DIY-Oil/Transmission Fluid change videos..... CRAIG2 Videos 2 05-13-2011 12:11 PM
Transmission problem vontoughguy Troubleshooting for Road Glides 4 08-19-2010 05:30 PM
