Troubleshooting- No Brake Lights - Road Glide Forums
post #1 of 11 (permalink) Old 06-08-2015, 10:08 AM Thread Starter
DED HD's Avatar
2010 FLTRX w/ ABS
So i went for a putt on Saturday, and was about a mile from home. I came to a stop sign, and my rear right turn signal cover vibrated off. I think because of my powder coating, the cover did not snap in as good as stock. But ive had it this way for 4 years(25,000 miles) without any issues. I have custom dynamic LED bulbs, and so the bulb was dangling there. I then realized, that my brake lights were not working.
I got home, pulled the bulb out, and re seated it and put the cover back on.
My running lights work, and my turn signals work, but no brake lights.
When i pull the front brake lever, i get a click from the fuse panel. When i push on the rear brake, i get the same click from the fuse panel. There is a relay there, and the same relay is used for other lighting. i swapped relays, and still get the same thing. I checked fuse, and swapped fuse and still same thing.
Can anybody help me solve this? Seems like it had to be something with the CD bulb.
Recent mods that may be possible causes- New front wheel, Swapped out rear fascia/tri bar light that i bought used on forum, but didnt have problems after hooking it up.
Maybe its the tri bar light connections?
help is appreciated. Thanks!
'10 Red Custom:
DED HD is offline
post #2 of 11 (permalink) Old 06-08-2015, 10:57 AM
Check the tabs inside the fuse box where the brake light fuse goes. I had the tabs spread and they didn't make contact with the prongs on the fuse (I think it is a heat related problem), take a small flat screwdriver and bend the tabs in the fuse box in so it will make contact with the prongs on the fuse.
Not saying that this will fix your problem but it is something to check.
post #3 of 11 (permalink) Old 06-08-2015, 11:57 AM
Are you sure the bulb is good ?? The Brake light bulb should be a double filament , and it's possible, one side burned out.
Big_gary is online now
post #4 of 11 (permalink) Old 06-08-2015, 12:08 PM
tdkkart's Avatar
Check your grounds, LED bulbs draw so little current that high resistance grounds can be an issue. Try a regular bulb in place of the LED.
tdkkart is offline
post #5 of 11 (permalink) Old 06-08-2015, 12:40 PM
Missed the LED. part... regardless, try a new regular bulb. Easiest first.
post #6 of 11 (permalink) Old 06-08-2015, 01:43 PM
glidethru's Avatar
My wife's 05 Electra glide was doing the same thing.....replaced the actual part that the bulb connects to in the rear light housing...problem solved
MAGNA FLOW "Top Guns
Wild Ones 12" Chubbys
glidethru is offline
post #7 of 11 (permalink) Old 06-08-2015, 02:06 PM Thread Starter
DED HD's Avatar
thanks for the replies so far guys. i will check into grounds, fuses, stock bulb and i just might have an extra housing.
'10 Red Custom:
DED HD is offline
post #8 of 11 (permalink) Old 06-08-2015, 02:22 PM
mjsdouble's Avatar
It could be your brake switch.
mjsdouble is offline
post #9 of 11 (permalink) Old 06-08-2015, 04:18 PM
tdkkart's Avatar
If the relay is clicking the front and rear switches are OK. The switches trip the relay, the relay switches power to the bulbs.
tdkkart is offline
post #10 of 11 (permalink) Old 06-08-2015, 04:23 PM Thread Starter
DED HD's Avatar
This is helping narrow it down.
i think i will check the wiring harness where it connects at the tri bar light.
i have another tri bar light i can use too. And i will also check the connectors inside the bulb housing.
Thank you!
'10 Red Custom:
DED HD is offline
No Turn Signals, Running Lights, or Brake lights on 15 FLTRXS warbird458 Lighting 5 07-12-2016 08:02 AM
Need help troubleshooting J&M Rokker installation Stick_FSMC Audio 18 07-01-2012 12:34 PM
Need help troubleshooting J&M Rokker installation Stick_FSMC J&M 2 06-04-2012 12:12 PM
Beer troubleshooting Eric92 General Off-Topic Discussions 11 12-26-2011 09:15 AM
No Cruise, No Brake Lights , engine light and lots of codes DonJulio Troubleshooting for Road Glides 4 07-24-2011 06:02 PM
