Starter issue - Road Glide Forums
post #1 of 4 (permalink) Old 06-12-2015, 07:46 AM Thread Starter
Knuckles's Avatar
Starter issue
Has anyone broke the jack shaft on the starter? Went to go for my first "ride" of the year and my starter clunked then just went zing. I pulled the starter off and the shaft with the gear that makes contact with the flywheel was not attached! I pulled the primary cover and there it was laying on the bottom. I have a new starter (lifetime warranty from All Balls) but I'm wondering if there is other issues that I need to address.
Any input from you guys and gals would be greatly appreciated.
S&S 106 big bore, 585 cams, headwork, timken conversion, welded and trued crank, foundation done the rest is trivial and fun to change
Knuckles is offline
post #2 of 4 (permalink) Old 06-12-2015, 10:16 AM
It is pretty uncommon for the starter shaft to break. I would check your compression releases and see if they are working correctly.
Even if the compression releases were not working at all the starter shaft shouldn't have broken, I would think it is just a faulty starter.
post #3 of 4 (permalink) Old 06-12-2015, 11:37 AM Thread Starter
Knuckles's Avatar
That's what I'm hoping for, I really haven't had much time to ride this year and this just pissed me off a bit.
I'll be putting everything back together tonight and then it's two days off for some much needed two wheel therapy
Knuckles is offline
post #4 of 4 (permalink) Old 06-12-2015, 03:37 PM
Check the teeth on the flywheel to make sure they are still intact. Make sure the starter gear didn't damage any when it broke
1990 tour glide starter issue glidelover69 New Members Welcome Area 22 05-15-2013 09:07 PM
Starter Hesitation & Fuel Range reading Cotton Hill Troubleshooting for Road Glides 4 05-27-2011 09:37 AM
Rebuild silenoid or replace starter? krgs2k Troubleshooting for Road Glides 6 04-20-2011 05:01 AM
Spyke starter issues Hotroadking Troubleshooting for Road Glides 2 02-15-2011 01:05 PM
Starter Marks07RG Equipment-RG 1 09-21-2010 06:42 PM
