NO OIL and no idiot light?? - Road Glide Forums
post #1 of 17 (permalink) Old 06-15-2015, 08:07 AM Thread Starter
motodrummer's Avatar
Unhappy NO OIL and no idiot light??
While riding yesterday I noticed a really loud knock coming from engine and also noticed the oil pressure slowly fluctuating between 32 and 5. I figured either my oil pump was going bad or I had a clogged filter.
I checked the oil level when I got home and it was completely bone ass dry? How can these be and the idiot light not come on? it comes on when I turn the ignition on?
I checked the oil level in April and it was good, I have zero smoke coming out of the exhaust and no other indications of leaking oil. I leave it parked in my shed and there is no oil on the floor.
Is there another place this oil could be going? The bike has run great otherwise.
Any ideas or things to look for? I am thinking of just refilling with oil and monitoring it very closely. I changed the oil and filter in November and the bike was sitting till April before taking her out and riding her, so far it has about 3000 miles since last oil/filter change?
motodrummer is offline
post #2 of 17 (permalink) Old 06-15-2015, 08:37 AM
Back when I had my first Harley in the 90's they had an issue with motor oil draining out into the primary. Just a thought given the lack of leaks or blue smoke.
Jeff
Jeff396 is offline
post #3 of 17 (permalink) Old 06-15-2015, 09:45 AM
BDMastiff's Avatar
I'm guessing you should have heard your valve train clicking very loud and seen a drastic drop in oil pressure after being 1.5-2 quarts low. It's strange that there wasn't any indication until you were bone dry. I recommend you carry a quart of oil and a paper cone on your bike until you find the cause of the problem. Keep a close eye on the oil pressure gauge and listen to the sounds of your bike. I'm a novice mechanic so I won't make any recommendation about fixing it.
Just an after thought. You may want to use a motor oil with Zinc in it. It will protect your engine. Look into Brad Penn Oil (Formerly Kendall Oil).
1996 Fatboy
BDMastiff is offline
post #4 of 17 (permalink) Old 06-15-2015, 10:13 AM Thread Starter
Yeah to be honest I may have noticed a lil more noise than usual but ignored it like a moron. It would come and go and I do have a small squeal somewhere in the back of the bike that I been trying to catch so I was a little preoccupied with that. Harley oil is good, I mean if it ran that far with no oil I am thinking it is good stuff as now that I am aware of it I will not run it that low again.
post #5 of 17 (permalink) Old 06-15-2015, 10:41 AM
HellInABucket's Avatar
I wonder if its an inner primary seal or race leak?
motodrummer, you might crack open your derby cover to see whats going on...
HellInABucket is online now
post #6 of 17 (permalink) Old 06-15-2015, 10:42 AM Thread Starter
what should I expect to see normally if I open the derby cover? Should I get any fluid out at all on the kickstand?
post #7 of 17 (permalink) Old 06-15-2015, 10:46 AM
We're you drinking heavy when you changed the oil in November, and forgot to add the oil ?
How's it running ?
Big_gary is online now
post #8 of 17 (permalink) Old 06-15-2015, 10:50 AM Thread Starter
How's it running ?
While I cant completely rule that out it is very unlikely : ) It seemed to be running the same as always, did not notice any power loss or nothing like that
post #9 of 17 (permalink) Old 06-15-2015, 10:57 AM
Under normal circumstances (with no issues) you should only remove the derby cover while the bike is upright, not on the jiffy stand, otherwise you'll get oil running out of the primary because the normal level is right at the bottom lip of the derby cover opening.
So I would put it on a jack and check, if a lot of oil comes out while vertical, then you might have a problem.
post #10 of 17 (permalink) Old 06-15-2015, 01:12 PM
Bleachey's Avatar
Bleachey is offline
Low oil lamp / idiot light - 2018 M8 Beerme Engine Related 18 07-15-2018 04:17 PM
Dropped my 2010 FLTRX last Friday...I'm an idiot Chaz *General Road Glide Discussions/Pictures 27 08-18-2012 05:49 PM
Idiot ruined my windshield faststan Windshields 17 03-09-2012 11:03 AM
I'm an Idiot! hodgeaaco *General Road Glide Discussions/Pictures 14 09-20-2011 08:04 PM
No Cruise, No Brake Lights , engine light and lots of codes DonJulio Troubleshooting for Road Glides 4 07-24-2011 06:02 PM
