No tail light or front brake light - Road Glide Forums
post #1 of 4 (permalink) Old 06-23-2015, 10:11 AM Thread Starter
I just got done installing a rear air ride system on my 2005 Roadie checked all clearances with bike completely laid out. Rode it that way for less than 5 miles. Everything seemed fine. 3-500 miles later all the sudden no rear tail light or front brake light when lever is pulled in. I still have rear brake light and hear the "click" when i push it down. Front brake lever gets pulled in and no click. I have checked all the fuses and they seem fine also wiring under the fender seems intact. Any ideas on where to go next? It is a led light and I also tried with a stock light...same deal
hummbusa is offline
post #2 of 4 (permalink) Old 06-23-2015, 11:34 AM
HellInABucket's Avatar
Front brake light?
HellInABucket is online now
post #3 of 4 (permalink) Old 06-23-2015, 11:57 AM Thread Starter
I mean when I pull in the brake lever the light won't come on...
hummbusa is offline
post #4 of 4 (permalink) Old 06-23-2015, 12:00 PM
The brake light malfunction may be in the brake relay which should be located in the fuse block and it may also be the problem with the running lights. If the brake relay is OK then check the brake light switch in the switch housing. I would think that brake switch is not working right because the brake light works when you use the back brake.
The running light problem may be a ground problem so check and clean all the ground connections you can find that is related to the lighting, if it is a bad ground it may correct the brake light problem too.
Help-no headlights or tail light scteach Troubleshooting for Road Glides 7 04-28-2019 06:16 PM
Changed front tire now no front brake??? jrbean1 Troubleshooting for Road Glides 9 07-24-2014 11:05 PM
No Cruise, No Brake Lights , engine light and lots of codes DonJulio Troubleshooting for Road Glides 4 07-24-2011 06:02 PM
3RD Brake Light/TourPak Rack & StreetGlide Rear Facia w/tail/stop light paco ritter Aftermarket Accessories 6 04-20-2011 11:00 PM
2009 Brake/Tail light bezel options???? Big Dirty Lighting 0 10-04-2010 01:35 AM
