Primary fluid leaking at derby cover - Road Glide Forums
post #1 of 11 (permalink) Old 06-23-2015, 09:28 PM Thread Starter
Shemp's Avatar
Got home from Shark Week V, 3000 miles on fluid change. No evidence of a leak through the whole trip. Bike was washed and parked for the last two days while I was working, got home this afternoon to this....
It appears to be leaking from the derby cover, using a paper gasket (new style rubber doesn't fit this derby cover).
Question... Going to replace the gasket and retorque the screws but is there anything else I need to pay attention to? Should I drain the primary and replace the fluid again with the correct amount?
2011 RGU Merlot/Sunglo, Daymakers, 13" Madstad dark grey windshield, LED tourpac lights, SE RT/SE AC, Bassani Road Rage 2/1 pipes, Wild 1 10" mini apes, Street Glide fascia.
Miles of twisting mountain roads with no guardrails!
Shemp is offline
post #2 of 11 (permalink) Old 06-23-2015, 11:04 PM
Don't know how much fluid you're putting in but the level shouldn't be reaching the derby cover just sitting on the kick stand. When you do remove the cover make sure you wipe it down good and check for any cracks on both the derby cover and outer primary cover. Replace it with whatever gasket it requires
post #3 of 11 (permalink) Old 06-23-2015, 11:09 PM
Odd, though about time for fluid changes anyways, on the 2nd primary (still have the first for a backup) gasket on brought new 03 > 97k, but don't tell anybody else on here
reds4 is offline
post #4 of 11 (permalink) Old 06-24-2015, 06:26 AM
Harleyagain's Avatar
If you haven't already, make sure you tighten the cover using the suggested tighten sequence.
Bob
Harleyagain is offline
post #5 of 11 (permalink) Old 06-24-2015, 06:51 AM
if you don;t like the torex
screws, go to ACE hardware, they have chrome allen head screws, be sure you measure the length of you torex ones in order to get the correct length
brownfoxx1 is offline
post #6 of 11 (permalink) Old 06-24-2015, 07:15 AM Thread Starter
Shemp's Avatar
38oz of primary fluid what i changed it out just before shark week. No leak until i got home. I'll pull the derby cover and check it all out. Is there any way engine oil can transfer into the primary making it too full?
Shemp is offline
post #7 of 11 (permalink) Old 06-24-2015, 09:54 AM
Yes the engine oil could go into the primary but it isn't a common problem. It looks like the derby gasket is failing or the derby cover is loose.
You probably didn't lose too much fluid, when you pull the derby cover just check and see if the fluid in at the bottom of the clutch basket, if it is then you will be good.
+1 on the allen screws, I use Stainless screws.
post #8 of 11 (permalink) Old 06-24-2015, 11:12 AM
I'd be the last one and not disagree with Fe Mark, SS screws (fasteners) have more bite some thicker pitch, use caution
reds4 is offline
post #9 of 11 (permalink) Old 06-24-2015, 07:57 PM Thread Starter
Shemp's Avatar
Just wanted to thank everyone for the responses, and MJsDouble for the phone call. Pulled the derby cover today expecting the worst, hoping for the best and found the fluid level the same as freshly filled. The paper gasket was not torn but looked like it had a crease in it. I guess that was enough to collect Primary fluid and then drain out when it finally sat long enough.
Went ahead and changed out the primary fluid cause I had it opened up. Going to do a 1000 mile plus tour of Colorado with my son starting the 4th!
Stay safe friends!
Shemp is offline
post #10 of 11 (permalink) Old 06-24-2015, 10:47 PM
mjsdouble's Avatar
Happy to hear it was a simple fix Curtis. Enjoy your trip with your son.
mjsdouble is offline
New Derby/Fuel Door Cover/Timing Cover - D&L Derby Cappers REDRUM *General Road Glide Discussions/Pictures 4 06-09-2014 06:52 PM
leaking brake fluid THEMASTERDESTROYER Fluids and Lubricants 16 04-11-2014 10:05 PM
2009 Chrome Outer Primary and Derby Cover METIME Parts for Sale 3 06-11-2013 12:49 PM
Solo seat, BN bag liners, derby cover, primary cover SIC_26 Classifieds Archive (3 months old+) 15 12-27-2012 06:06 PM
Willie G Derby and Chrome Primary cover Brent376 Miscellaneous for Sale 4 12-10-2012 01:26 AM
