Oil Spray - Road Glide Forums
post #1 of 10 (permalink) Old 07-04-2015, 05:04 AM Thread Starter
Oil Spray
After dismounting my 2003 RG when I arrived at work tonight I noticed oil had sprayed out over my saddlebags, tourpack, and the right side of the seats. I lost a considerable amount of oil over the 70 mile commute into work. I did stop for gas 30 miles in so the loss of oil occured during the last 40 miles. It appears to be comming from the behind the air cleaner cover but I won't be able to confirm that until I can get the correct allen wrench to remove the cover and air filter. Any ideas on what would have caused this? I've had no issues prior to tonight and have logged 2700+ miles since my last oil change.
2003 Anniversary Road Glide.
Neil V. is offline
post #2 of 10 (permalink) Old 07-04-2015, 07:43 AM
FrankieB's Avatar
It sounds like it puked oil out the head vents. The usual cause is running to much oil. I run mine with 3 1/2 to 3 3/4qts, any more then that I get a lot of blow by. Once you get it cleaned up, I would also keep an eye on the push rod tubes just to make sure one of the O-rings hasn't started leaking.
06 RK
11 RGU
FrankieB is offline
post #3 of 10 (permalink) Old 07-04-2015, 08:16 AM
RGKen's Avatar
+1^^^
2018 FLTRXS
RGKen is offline
post #4 of 10 (permalink) Old 07-04-2015, 11:00 AM
skratch's Avatar
did you verify this with an oil level check? usually blow by, while it looks like a ton of oil, is actually not that much. if you did in fact lose a 'considerable' amount, then you might have another issue going on as well.
skratch is online now
post #5 of 10 (permalink) Old 07-04-2015, 12:06 PM
have logged 2700+ miles since my last oil change.[/QUOTE]
What did you come up with? After you get some coffee in you, of course
reds4 is offline
post #6 of 10 (permalink) Old 07-04-2015, 03:34 PM Thread Starter
What did you come up with? After you get some coffee in you, of course[/QUOTE]
A friend with a Road King had a similar problem earlier this summer and he had to replace the gasket on the gear case cover timing bore. I left the bike at work and will take advantage of my H.O.G. membership to have it towed to a dealership on Monday.
Neil V. is offline
post #7 of 10 (permalink) Old 07-05-2015, 05:25 PM
chilidogtampa's Avatar
im just gonna sit here and wait until somebody mentions the maxipad trick...
my 2001 was like Frankie said, I would run it about half a quart low and even then if I hauled ass for a good run like 80+ sustained for an hour or so I would get mist out of the AC.
like alot of Harley issues you can throw money at it or take the easy route.
c'mon who is gonna bring up the Maxipad...
chilidogtampa is offline
post #8 of 10 (permalink) Old 07-05-2015, 06:40 PM
RoadGlide69's Avatar
Hi, I'm Roadglide 69 and I've used a maxipad with my 09 RG.
2011 FLTRU Sunglo Merlot, VH Big Shot Duals, PC-V, A/N Big Sucker, CV Flasher & 14" WindVest Shield
RoadGlide69 is offline
post #9 of 10 (permalink) Old 07-05-2015, 06:41 PM
Damn things are absorbent!
post #10 of 10 (permalink) Old 07-06-2015, 10:49 PM
bikepsych's Avatar
On my 09 RG there was apparently two tech bulletins. One was an updated set of breather valves in the heads. The other was to drill two holes in each of the heads to let oil flow back down to the sump faster. Since I've had both of these done, no problems at all.
But yes, a maxipad does indeed reside in my airfilter cover.
BG
bikepsych, 2017 RoadGlide Ultra
Supertrapp Fatshots, SE A/C, 107 2 114 kit
bikepsych is offline
Oil Spray on front right side exhaust and platform 2016CTRoadGlide Engine Related 4 08-17-2017 11:42 AM
Oil Spray Problem Resolved. Neil V. Troubleshooting for Road Glides 9 08-18-2015 10:27 PM
Update on Oil Spray Problem Neil V. Troubleshooting for Road Glides 5 07-14-2015 06:20 PM
Spray-on Wax oofly *General Road Glide Discussions/Pictures 23 09-27-2011 10:26 PM
Annoying Fuel Spray Timinfla2 *General Road Glide Discussions/Pictures 43 05-14-2011 01:56 PM
