HELP!!! TAC & SPEEDO stuck, wont start - Road Glide Forums
post #1 of 21 (permalink) Old 07-05-2015, 12:53 PM Thread Starter
TYM2GLIDE's Avatar
Looking for a little help. I started my bike up at a store to go home and within minutes the TAC and Speed odometer started flashing, a red key showed up. the bike was running fine and did not go into limp mode and I made it home.
Now the TAC and Speed Odometer are stuck and will not show lights.
Actions Taken:
I have checked fuses and cannot find any blown. I have checked the battery connections and all seems good.
The bike radio will power on, the pump for the EFI will power on, the turn signals do not work but the lights do.
Adding, this bike does not have the security option.
I cannot get into the diagnostics menue as the tac and speed O do not seem to work at this moment.
looking for a little help from the smart people before I breakdown and take it to the dealership.
Semper Fi
Scott
2012 FLTRX, 4" Rineharts, V&H Naked V02, FullSack Head Pipe, 14" Malo's, Topshop Minister Fender & Viper bags, 21in Hogpro Titan wheel, Progressive monotubes with 1in drop, Andrews 57H cams.
TYM2GLIDE is offline
post #2 of 21 (permalink) Old 07-05-2015, 12:55 PM
Fob battery?
post #3 of 21 (permalink) Old 07-05-2015, 12:59 PM
Road Queen's Avatar
Send a message via Skype™ to Road Queen
My cruise control just stopped working! 2013 road glide ultra...ugh ideas?
Road Queen is offline
post #4 of 21 (permalink) Old 07-05-2015, 01:01 PM Thread Starter
TYM2GLIDE's Avatar
No fob with the bike, it does not have security.
post #5 of 21 (permalink) Old 07-05-2015, 01:50 PM
Actions Taken:
Semper Fi
Scott
Check fuse ?
post #6 of 21 (permalink) Old 07-05-2015, 02:19 PM Thread Starter
TYM2GLIDE's Avatar
no blown fuses
post #7 of 21 (permalink) Old 07-05-2015, 02:26 PM
Smarty's Avatar
Sounds like the sensor that detects the bike falling over and kills it. I've heard of that happening before. The speed sensor in the tranny I don't think will cause the blinkers to do that but not sure. Check it for debris on the end of it.
Smarty is offline
post #8 of 21 (permalink) Old 07-05-2015, 02:31 PM
Disconnect your battery and unplug and replug any connections under your seat. Had a similar problem and "reseting" those items solved it for me.
Minivend is offline
post #9 of 21 (permalink) Old 07-05-2015, 02:42 PM
+1^^^ or pull the main 40 amp fuse.
post #10 of 21 (permalink) Old 07-05-2015, 02:52 PM Thread Starter
TYM2GLIDE's Avatar
I have pulled and reset the 40 amp fuse, no change. I have not disconnected the battery yet. If it is the sensor that senses fall over and kills it, can that be reset?
Ignition switch Stuck & i mean stuck.... maddmoe Troubleshooting for Road Glides 11 07-08-2016 06:22 AM
LED insight video on speedometer and tac ScreamingSkulls Do-IT-Yourself 12 03-24-2015 02:25 PM
Speedo & Tac Light Mod Sneak Peak Donk Lighting 37 07-04-2013 10:33 AM
changed bars now bike wont start NO4NBIKES Controls & Handlebars 4 01-02-2012 11:06 AM
wont start The instigator Road Glide Specific Discussions 8 03-24-2011 10:20 PM
