Rattle - Road Glide Forums
post #1 of 8 (permalink) Old 07-10-2015, 07:46 PM Thread Starter
demoncruzer's Avatar
Rattle
I have a 2013 RG and am getting a rattle at idle when I pull in on the front brake lever,only happens at a complete stop. Any i deas would be appreciated.
demoncruzer is offline
post #2 of 8 (permalink) Old 07-10-2015, 09:36 PM
FrankieB's Avatar
Use your hand or a rubber mallet and start tapping stuff to see if it rattles. I would start with the front fender then to the fairing since it only happens when you clamp the front break.
06 RK
11 RGU
FrankieB is offline
post #3 of 8 (permalink) Old 07-10-2015, 10:13 PM
Did it just start, did you replace the handle bars, ect.? I always get a rattle when applying front brakes at idle, that's a common thing. Does it stop when you release the lever? If it were my bike I won't be tapping anything with a rubber mallet, especially the front fender or fairing!
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #4 of 8 (permalink) Old 07-10-2015, 10:27 PM
FrankieB's Avatar
The word was tap not hammer.
06 RK
11 RGU
FrankieB is offline
post #5 of 8 (permalink) Old 07-10-2015, 11:14 PM
Exclamation Yes, Tap
[QUOTE=FrankieB;2817930]The word was tap not hammer.[/QUOTE
I do know the difference, still doesn't change a thing I stated.
post #6 of 8 (permalink) Old 07-10-2015, 11:20 PM
Also check the shifter rod if it's the stock one with the $h!tty lil ball and socket thingys. I had a rattle that took me forever to find but it wound up being the shifter rod. I replaced the ends with a set of heim joints and the rattle was gone
post #7 of 8 (permalink) Old 07-11-2015, 12:14 AM
+1 rlaf75
WarBootie is offline
post #8 of 8 (permalink) Old 07-13-2015, 10:35 PM Thread Starter
as a matter of fact i did just do a bar swap, and didn't notice it after i completed the swap. It has been about 6 months since the swap and just started noticing it when applying the front brake. it goes away when i let off the brake lever. What did you find with yours?
Can you get Sedona Orange in a rattle can? Gadgetech *General Road Glide Discussions/Pictures 18 01-10-2017 12:34 AM
Rattle ohd24 Tech Area 2 01-21-2012 03:49 PM
2011 clacking/rattle at 2200 + RPM Passed Troubleshooting for Road Glides 22 07-30-2011 11:23 PM
Scarlet Red Rattle Can Sancho Do-IT-Yourself 12 11-29-2010 10:12 PM
Annoying clunk/rattle over bumps from front end GizmoGlide *General Road Glide Discussions/Pictures 17 04-01-2010 04:15 PM
