Is this the fix for some of our rocker box noise - Road Glide Forums
post #1 of 9 (permalink) Old 07-12-2015, 03:21 AM Thread Starter
Wood's Avatar
Found this nice write up on how OP fixed his rocker box noise.
http://www.hdforums.com/forum/new-ru...t-is-over.html
Wood is offline
post #2 of 9 (permalink) Old 07-12-2015, 10:38 AM
That loctite is only sustainable to 302 degrees Fahrenheit. I think our internal engines get a bit hotter than that. I dont think I want the stuff melting down into my engine then re hardening.
Big_gary is online now
post #3 of 9 (permalink) Old 07-12-2015, 11:17 AM
tdkkart's Avatar
It's a good find, but I think his fix is a bit weak. I'd be temped to either put in pins or setscrews to hold the shafts in place.
tdkkart is offline
post #4 of 9 (permalink) Old 07-12-2015, 11:27 AM
+1^^^.
What's going to happen when the loctite hardens and then breaks up and hard chunks of loctite go into the crankcase
Not only that the rocker arm assembly is designed to have a little side to side movement so everything will line up when the top end is assembled, as long as there is no up/down movement everything is OK.
If I read the article right the OP mentioned that there were no bushings in the rocker arms which is WRONG the rocker arm support plate have bushing on the ends where the end of the rocker arm shafts are. So if the OP doesn't have bushing in the support plate then HD forgot to install them.
I would stay away from doing this mod. JMO
post #5 of 9 (permalink) Old 07-12-2015, 01:54 PM Thread Starter
Wood's Avatar
Originally Posted by ironmark View Post
+1^^^.
Agree with your loctite comments... Going back to the rocker shaft; if you didn't view his video please do. It appears that the shaft is installed correctly and the shaft can partially rotate and make the tapping noise that were hear at times. Looks like this can be a real issue on some bikes or if HD really forgot to install bushings that is a bigger problem.
Wood is offline
post #6 of 9 (permalink) Old 07-17-2015, 03:11 PM Thread Starter
Wood's Avatar
Here's a thread from another forum that discusses this fix and some alternatives.
http://harleytechtalk.org/htt/index....107.0/all.html
Wood is offline
post #7 of 9 (permalink) Old 07-17-2015, 03:45 PM
PGR
PGR's Avatar
Ride a PanHead for a few hours, then get back on your bike. You'll be amazed how quiet your top end really is.
Ron..........................
PGR is offline
post #8 of 9 (permalink) Old 07-18-2015, 09:45 AM
Smarty's Avatar
There is a thread on Harley Tech Talk right now called interesting read. It gives the real fix for this problem. The best one I think is the one where they use a used rifle brass shell casing to sleeve where the bolt goes and tightens up the tolerences. Very good read.
Smarty is offline
post #9 of 9 (permalink) Old 07-19-2015, 04:11 AM Thread Starter
Wood's Avatar
My Pan Head was a little noisy, but in a good way just whirling away in harmony; besides I was having too much fun on it. My Shovel still purrs like a sewing machine.
Wood is offline
Fix it or 2015? FIX! 08Zinc Engine Related 24 02-14-2017 07:26 PM
Removing Rocker Box Cover Q-Hog Engine Related 2 03-12-2013 05:22 PM
Rocker box question?? 68 EB Engine Related 2 03-09-2013 02:54 PM
Twin Cam Rocker Box Covers Shrug Parts for Sale 0 02-26-2013 09:46 AM
Gloss Black HD Detachable Sissy Bar/Rocker Box Covers/Cam Cover Bigdaddymike Classifieds Archive (3 months old+) 7 01-26-2012 05:27 PM
