Cam Chain Tensioners - Road Glide Forums
post #1 of 13 (permalink) Old 09-09-2010, 12:08 AM Thread Starter
Ranger58's Avatar
Question Cam Chain Tensioners
Starting to hear the dreaded noise from the cam box and I'm wondering if anyone has undertaken the job of replacing the chain tensioners on an '04 or similar setup? Got any pointers for me? I knew the insides of a shovel like the back of my hand and now it's time to get intimate with the TwinCam. Thanks in advance!
Then: '81 Tourglide
Now: '04 RG, Stage 1, Smoothed and Chromed Factory Wheels, Chromed Fork Lowers, Polished Rotors, and she's aching for a 95", a Power Commander and another gear.
Ranger58 is offline
post #2 of 13 (permalink) Old 09-09-2010, 06:24 AM
HD-DOC's Avatar
You will need to inspect the tensoiners. The cam cover has to be removed, which meand the exhaust and right footbaord has to be removed to get it off. Once inside the outter tensioner is very easy to see if its worn, the inner has to be lifted a bit with a screw driver to see the pad at the top of the cam plate. If they are worn , and need to be replaced you will need to have the right tools to do the job. A manual is a must. The job is a pain in the butt with out the right tools and a press. Doc
HD-DOC is offline
post #3 of 13 (permalink) Old 09-09-2010, 08:44 AM
joke's Avatar
Lots of good info, pics, and videos on the HD Forum. I thought about doing the same on my Softail but bought the Roadie instead. Looks pretty straight forward...and you already sound mechanically inclined. Give it a go...
2009 Mirage Orange
joke is offline
post #4 of 13 (permalink) Old 09-09-2010, 10:19 AM
CHAINSAW's Avatar
Im not trying to sway you in any direction,.. but throw the idea around of going to a gear driven setup. You gain 8HP cam for cam with gear driven, and no worries about chain slap, clatter or breaking.
Such is the rule of honor.
CHAINSAW is offline
post #5 of 13 (permalink) Old 09-09-2010, 04:04 PM Thread Starter
Ranger58's Avatar
Chainsaw, talked with my mech/builder and he advised that the pinion shaft had to have less than 3/100ths runout to run the gears and I'm thinkin that with the nearly 30,000 on mine, that probably isn't going to be the case. That's the whole reason for going the replacement route; but, thanks anyways!
Doc, thanks for the heads up! I've got the shop manual, now to get my hands on the tools necessary for the job. May just pull the trigger and get the ones I need. Can't have too many tools in the ol box can Ya? I've got lots of them for the dearly departed Shovel.
Then: '81 Tourglide
Ranger58 is offline
post #6 of 13 (permalink) Old 09-10-2010, 07:29 AM
HD-DOC's Avatar
If I was you I would go with the andrews reto cams and 07 up camplate and pump, better scavenging and oil pressure and they seem to be holding up very good. Have done a few of these and they are a lot quieter than the gear drives. No specail tools for the install is a plus also. You would want to replace the inner cam bearings with the torrinton B-148 bearings which need a removel and install tool is needed, can be had for around $85.00 aftermarket. Doc
HD-DOC is offline
post #7 of 13 (permalink) Old 09-10-2010, 07:36 AM
HD-DOC's Avatar
[email protected] This guy sells the install and remover tool for $90.00 shipped to your house. Doc
HD-DOC is offline
post #8 of 13 (permalink) Old 09-10-2010, 07:45 AM
HD-DOC's Avatar
http://www.flyingwperformance.com/ This guy sells everything in one kit to upgrade to the 07 style camplate and pump. And I mean everything right done to the assembly lube. Doc
HD-DOC is offline
post #9 of 13 (permalink) Old 09-10-2010, 01:19 PM
BigDaveOnBass's Avatar
Send a message via Yahoo to BigDaveOnBass
I went this route. No regrets...
'04 FLTRI, originally Smokey Gold, now Vivid Black, 95", S/E forged high comp 9.6:1 pistons, Andrews 37G cams, Big Boyz heads, S/E adjustable pushrods, S/E Race Tuner, S/E Stage 1 kit, V&H Dresser Duals, S/E slip ons, H-D premium oil cooler, chromed wagon wheels, Brembo/H-D front brakes, added rear engine guards, Paul Yaffe 10" OEM Monkey Bars, detachable tour pak
BigDaveOnBass is offline
post #10 of 13 (permalink) Old 09-10-2010, 01:40 PM
+1 on the gear drive, 05 Road Glide. - Mike
mikek53 is offline
Cam Chain tensioners justincollins Engine Related 16 04-09-2014 10:36 AM
Checking cam chain tensioners groupw Engine Related 1 04-18-2013 08:05 PM
TC 88 Cam chain tensioners after 12,300 miles prince *General Road Glide Discussions/Pictures 5 03-19-2012 10:32 AM
Cam chain tensioners hotrodad Troubleshooting for Road Glides 10 02-09-2011 02:03 PM
