Battery Ground Location - Road Glide Forums
post #1 of 6 (permalink) Old 07-14-2015, 02:43 PM Thread Starter
bikepsych's Avatar
Hey gang. Darned if I can figure out where the ground from the battery to the frame/engine is. Does anyone have a picture or can tell me where it would be? I suspect I have a loose ground/corroded ground (meter on dash only shows 11 volts going down the road). I'd like to check the easy things first. Have a new battery in with 12.68 volts when sitting.
2009 FLTR
Thanks in advance.
Bruce
bikepsych, 2017 RoadGlide Ultra
Supertrapp Fatshots, SE A/C, 107 2 114 kit
bikepsych is offline
post #2 of 6 (permalink) Old 07-14-2015, 10:33 PM
You may have a bad regulator.
post #3 of 6 (permalink) Old 07-14-2015, 11:30 PM
Well ya know the hot goes to the starter and ground to the motor/frame, check from the starter hot to the bolt head by the oil return side of tranny with multi-meter set 20v for batt volts then on batt
reds4 is offline
post #4 of 6 (permalink) Old 07-16-2015, 09:31 PM Thread Starter
bikepsych's Avatar
That gives me 12.57 volts. So, why does the meter read 11.5 volts at 3000rpm? Should it not read the same for the meter on the dash and what I get with the DVM?
BG
post #5 of 6 (permalink) Old 07-16-2015, 10:14 PM
Mine reads @^ 14 at that rpm, fully charge or parrael your batt to charge, if there's gain when riding, after check batt again, then rectifer..have a beer and listen to COLT FORD
reds4 is offline
post #6 of 6 (permalink) Old 07-17-2015, 04:46 PM
DED HD's Avatar
'10 Red Custom:
DED HD is offline
2016 battery tender fuse location and size gdtanas Troubleshooting for Road Glides 1 05-05-2016 11:59 PM
2015 Amp Ground Location rrcrum Audio 12 11-12-2015 09:43 AM
Hotel Issues - location location location DreamRider ARCHIVES-SWII LeClaire, IA 29 07-11-2012 01:40 PM
Battery location Gunny58 *General Road Glide Discussions/Pictures 21 03-22-2011 11:55 AM
Putting the Glide on the Ground??? jbrawkus *General Road Glide Discussions/Pictures 10 01-11-2011 09:30 PM
