Dark Custom derby cover - Road Glide Forums
post #1 of 11 (permalink) Old 07-17-2015, 03:09 PM Thread Starter
Blackbag1's Avatar
I have a Dark Custom derby cover (part# 25700434) on my '15 RGS. I also use gasket #25416-99C with the red sealant toward the clutch. I've done five primary fluid changes during the bike's 13000 miles and used a new gasket at each service. Ive used the same derby cover T27 torx screws that originally came with the bike and torque them to 108inlb spec. The fluid gets drained overnight and I pour exactly 38oz of fluids, the last two being Formula+.
I've developed an oil seep at the 6 o'clock position on the derby cover since the 2nd oil change. The derby cover looks undamaged and the bike has never been dropped. What could be causing the seep that eventually causes the front of the left bag and left cross-over shield and muffler to be covered with a mist upon post-ride inspection?
2015 Vivid Black FLTRXS...ridin' dahellouttavit (27k miles...and still counting!!!)
"I'm not talkin' about pleasure boatin' or day sailin'. I'm talkin' about workin' for a livin'. I'm talkin' about sharkin'." - Quint
Blackbag1 is offline
post #2 of 11 (permalink) Old 07-17-2015, 03:48 PM
PGR
PGR's Avatar
Possibly your derby cover is warped.
Ron..........................
PGR is offline
post #3 of 11 (permalink) Old 07-18-2015, 12:27 AM Thread Starter
Blackbag1's Avatar
I'd be very surprised if this derby cover is warped...its pretty thick billet aluminum. I guess its time to find a piece of thick glass plate and check the cover for warpage.
post #4 of 11 (permalink) Old 07-18-2015, 07:35 AM
redbaron's Avatar
Put your Derby cover on a flat surface ( like a granite counter top, steel plate etc. and see if it laying flat or if it rocks....that either prove or eliminates the possibility.
2012 Vivid Black, FM Ceramic 2-1-2 Header + 4" slash up mufflers Power Vision, PM Super Gas MERC A/C, 12" Windvest, CVO Solo Seat, XT Rokker & Hawgwire cs300 Amp, 10" Outlawz, CD Led's, Arlen Ness lowers, Ohlins S36E + progressive monotubes
redbaron is offline
post #5 of 11 (permalink) Old 07-19-2015, 04:50 PM Thread Starter
Blackbag1's Avatar
I conducted the glass test and it's as flat as the glass...no rocking, no detectable warp. I haven't detected a hairline or larger crack anywhere on the derby cover or the outer primary cover around the screw holes or mating surfaces. The 27t torx screws are good. The oil level is good with probably a minuscule amount (drips/spots worth) less than required 38oz.
For shitsngrinz I doubled up on the gasket (one with 2k-miles, the other with 5k-miles) and torqued it to its 108inlb specs in the proper sequence to see if this added thickness will help the gasket that's making contact with the outer primary cover have a better seal without over-torquing the screws...dunno if that makes sense but it's worth a shot since it's only seeping at the bottom between 4 and 8 o'clock screws on the derby and maybe needs that little extra push at the 6o'clock position where there isn't a screw so it can seal properly...and I have had them hanging around anyway.
I cleaned and sprayed the wet oily areas the seepage created with brake-kleen and wiped off my left bag, side cover, and muffler...and will give it another run.
Report to follow.......
post #6 of 11 (permalink) Old 07-19-2015, 05:34 PM
mjsdouble's Avatar
I hope it's as simple as a faulty gasket.
mjsdouble is offline
post #7 of 11 (permalink) Old 07-19-2015, 06:03 PM Thread Starter
Blackbag1's Avatar
Me, too. Kenny...but that'd mean I've had three faulty gaskets in a row . I don't know if my daily 3100rpm/80mph (indicated) constant for 40-minutes (one-way) commute runs up and down the 15 has anything to do with it.
post #8 of 11 (permalink) Old 07-19-2015, 06:16 PM
Put the stock derby cover back on with the same gasket that is on the bike now and see if the oil leak goes away, if it does then the problem would be in the derby cover if it doesn't then try a new gasket with the stock derby cover.
If the oil leaks is still there with any combination of the stock derby cover and a new gasket then you may have a problem with the outer primary cover.
80 mph for 40 minutes won't hurt your derby cover or anything else, if it did my bike would be broke long ago.
post #9 of 11 (permalink) Old 07-19-2015, 09:25 PM Thread Starter
Blackbag1's Avatar
Good to know!...and I'll work on your systematic process of elimination
post #10 of 11 (permalink) Old 07-21-2015, 05:59 PM Thread Starter
Blackbag1's Avatar
I think I've solved my derby cover leak problem: For THIS particular bike with THIS particular billet derby cover, it takes TWO gaskets to create a proper leak-free seep-free seal. It's a good thing that I've saved all my used 5000-mile gaskets and was able to experiment with it instead of taking it to the dealership and their schedules. 200+ miles and no sign of spray on my left bag and muffler...no sign of drip where it's parked, no sign of fluid building up for a drip. HAPPY HAPPY HAPPY
#1 Dark Custom ~ Derby & Timer Cover FlatOut Parts for Sale 10 01-30-2015 05:19 AM
New Derby/Fuel Door Cover/Timing Cover - D&L Derby Cappers REDRUM *General Road Glide Discussions/Pictures 4 06-09-2014 06:52 PM
Derby Cover / Air Cleaner Cover Jetman Parts for Sale 9 09-08-2013 04:57 PM
Harley dark custom derby cover 25562-09 Napper Sold 2 01-18-2013 10:51 PM
Solo seat, BN bag liners, derby cover, primary cover SIC_26 Classifieds Archive (3 months old+) 15 12-27-2012 06:06 PM
