After Tire change rear break really hard?? - Road Glide Forums
post #1 of 5 (permalink) Old 07-25-2015, 10:35 AM Thread Starter
motodrummer's Avatar
Unhappy After Tire change rear break really hard??
Took my bike and a new tire and had a shop change the tire for me. When I left and went down road I noticed the rear brake is very hard to press and does not stop all that well as before. Any ideas what he could have done that screwed this up? I will call today but is there anything I can look at?
motodrummer is offline
post #2 of 5 (permalink) Old 07-25-2015, 10:45 AM
What year bike and does the bike have ABS brakes??
post #3 of 5 (permalink) Old 07-25-2015, 10:51 AM Thread Starter
2009 and yes it does have ABS
post #4 of 5 (permalink) Old 07-25-2015, 10:59 AM
Did you check if the ABS wire is connected. There is no reason for the person doing the tire change to do anything to the brake caliper or pads except to spread the pads a little to make it easier to put the caliper back on the bike. To spread the pads there is no need to pull the cover off the brake fluid reservoir either, you may want to pull the back calipers and check everything including the brake pads which may be worn out and the pistons on the calipers are extended to the max.
post #5 of 5 (permalink) Old 07-25-2015, 11:38 AM Thread Starter
I will check the wire but the rear pads were just changed out about 500 miles ago
Handlebar install - How hard, really bsquared Controls & Handlebars 11 03-04-2016 07:59 AM
Break-in Before Tune After Cam/Piston Install? Screamin' Engine Related 4 04-10-2015 11:19 PM
Trans oil really, really hot! August Fluids and Lubricants 6 09-12-2014 05:44 PM
I really really like my RGU . . . . RonC26 *General Road Glide Discussions/Pictures 18 09-02-2014 06:55 PM
I'm just being really really picky... BDMastiff *General Road Glide Discussions/Pictures 13 12-31-2010 11:11 PM
