2013 CVO high speed wobble - Road Glide Forums
post #1 of 3 (permalink) Old 07-30-2015, 11:20 AM Thread Starter
My 2013 has a high speed wobble that kicks in at about 80. This is 3rd front tire and 1st Dunlop E3 but has done it on all 3. Dealer found broken rear exhaust mount but that wasnt cure. Any ideas? Tire pressures checked regularly.
rcrocker is offline
post #2 of 3 (permalink) Old 07-30-2015, 11:30 AM
mouser58's Avatar
Steering head bearing need tightened???
mouser58 is offline
post #3 of 3 (permalink) Old 07-30-2015, 11:40 AM
I would assume that when the tires are mounted they are spin balanced! Spin balancing will also tell if the wheel is bent or not.
The 2009 and later bikes bike have had a history of front wheel bearing failure so that may be something that should be checked.
Also there is a history of the 2009 and later model having loose a steering head and the steering head may need tightening.
15 Road Glide High Speed Wobble Tinsleytown Troubleshooting for Road Glides 43 05-10-2016 09:53 AM
wobble at high speed offramps roadkiller Suspensions 5 08-04-2013 10:28 PM
High Speed Wobble..... not all the time.. SIG556 Troubleshooting for Road Glides 4 09-19-2012 10:01 PM
High Speed Sweeper Wobble? FLTRI *General Road Glide Discussions/Pictures 5 09-17-2010 12:39 PM
High Speed wobble on rear end Hub *General Road Glide Discussions/Pictures 0 06-28-2010 08:28 PM
