High beam indicator flickering. - Road Glide Forums
post #1 of 3 (permalink) Old 07-31-2015, 11:06 PM Thread Starter
Question High beam indicator flickering.
High beam indicator has started to come partially on and flickered. I dont notice any headlight flickering when it is doing it.
I just remounted the fairing. I slid the headlights in afterwards and dont think I have any wire pinching.
I do have the fuel moto led bulbs. Put about 4k on with them with no issues. But they do stick further our in the rear than stock.
Any ideas?
Fuel Moto header (no cat) Jackpot 2 1/2 mufflers, PV by Fuel Moto, BAL1, Woods 222 cam
baldwookie is offline
post #2 of 3 (permalink) Old 08-01-2015, 10:52 AM
Put the stock light bulbs back in and see if the high beam light stop flickering, if it does then I would think that the new headlight bulbs may be the issue.
post #3 of 3 (permalink) Old 08-01-2015, 09:57 PM Thread Starter
you are correct, I put the stock back in and no flicker. The led plug did not fit as snug as the stock, so I bent the bikes female contacts slightly so the leds plugged in tighter. That seems to have worked. Rode 4 hours, no flickering
High beam indicator flickering. baldwookie Lighting 1 08-01-2015 10:01 PM
Lights dim out - high beam indicator comes on.. jupiter Lighting 2 05-15-2014 11:25 AM
Daymaker light pattern (high Beam) txflyer Lighting 0 05-23-2013 06:23 PM
HID High Beam Low Beam Fit EasternSP Lighting 9 09-29-2012 01:05 AM
How high should high beam really be jacksonfdny Lighting 4 09-11-2012 06:37 AM
