Brembo Brake Issue - Road Glide Forums
post #1 of 10 (permalink) Old 08-04-2015, 01:44 AM Thread Starter
Hammer Down's Avatar
Brembo Brake Issue
My 2010 RG has been having an on again off again front brake problem. The front brakes were hanging up pretty bad but I took the calipers apart, cleaned them real good with ether, cleaned and polished the pucks, put it all back together and it has worked good for a couple of months..... until today..... now it (the front) is hanging up and driving me nuts!!!!! I can hear it, smell it and it drives me nuts!! It has brand new Lyndall Pads in it and I actually have the seals to rebuild the calipers on my shelf in the garage. Is it necessary? Thanks for the help!!!!
2010 RG Custom, S&S 106, Dan Vance Racing Heads, Cycle Rama 575 cams and lifters, SE Adj pushrods, Dan Vance 54mm Throttle Body, Dragos 2:1 Exhaust, DynoJet Power Vision with tunes from Fuel Moto customized by me.
Hammer Down is offline
post #2 of 10 (permalink) Old 08-04-2015, 10:58 AM
Might have warped rotors.
Big_gary is online now
post #3 of 10 (permalink) Old 08-04-2015, 07:45 PM Thread Starter
Thats an idea Big_Gary.... I honestly dont know..... The brake lever was fine today, but I also havent ridden it today. I would like to hear if someone can confirm the warped rotor theory before I spend a couple hundred on new rotor.
post #4 of 10 (permalink) Old 08-04-2015, 08:02 PM
Do you have abs ?
post #5 of 10 (permalink) Old 08-04-2015, 08:26 PM
When do they start hanging up? When you've been riding for awhile so they're hot or rather quickly into the ride?
post #6 of 10 (permalink) Old 08-04-2015, 10:51 PM
RFG7680's Avatar
Do you feel a chatter in the front end when you just start to apply the brakes? Mine were warped on my SG. That's what I noticed.
RFG7680 is online now
post #7 of 10 (permalink) Old 08-05-2015, 04:19 AM Thread Starter
Do you have abs ?
I do have ABS.
It usually happens short time in to the ride, less than 5 miles. It was hanging up on monday night when I pulled in to the garage and when I checked it yesterday afternoon it was normal again.
I dont feel and chatter, the front end feels the same as usual.
post #8 of 10 (permalink) Old 08-05-2015, 10:01 AM
I do have ABS.
I'd look more at the abs then, than the warped rotors. Warped rotors wil be more consistent.
post #9 of 10 (permalink) Old 08-05-2015, 11:48 AM
I would rebuild the calipers as soon as you can.
If you don't have warped rotors now you will real soon because of the extra heat, a warped rotor will have a pulsation when applying the brakes so if you don't have the pulsation then the rotors are good, if you have the pulsation then you will need new rotors.
post #10 of 10 (permalink) Old 08-05-2015, 12:49 PM
You may have a bad brake hose. They act normal when cold but add heat and they can swell and close.
Harley Brembo Rear Brake Caliper & Mount bykw2 Parts for Sale 5 07-28-2018 10:22 PM
Harley Brembo Brake Calipers shells & Brake lines bykw2 Parts for Sale 1 06-13-2018 05:22 AM
Brembo Brake upgrade Lacyvilla *General Road Glide Discussions/Pictures 4 09-25-2017 09:42 PM
Brembo issue? Rte 66 Road Glide Troubleshooting for Road Glides 28 07-01-2014 07:55 PM
Brembo Brake Calipers METIME Parts for Sale 5 06-27-2013 01:28 PM
