Oil Overfill and Check Engine light - Road Glide Forums
post #1 of 6 (permalink) Old 09-13-2010, 10:00 PM Thread Starter
'09 Road Glide After overfilling the crank case, I experienced excess oil spatter from the breather. I have since corrected the oil level, but the check engine light comes on occasionally. Usually after sever miles and it seems like only when I come to a stop. Engine seems to run rough and lacks power when it comes on. Unfortunately I have a trip planned in a week and the harley service dept locally can't schedule in time. Any Ideas?
HELP please.
Tom
Biker Tom is offline
post #2 of 6 (permalink) Old 09-14-2010, 07:13 AM
HD-DOC's Avatar
Check to see what codes it is throwing. Doc The retrival pdf is to large to post here.
HD-DOC is offline
post #3 of 6 (permalink) Old 09-14-2010, 09:52 AM Thread Starter
Thanks Doc. How do I find these codes and what is the retrival .pdf? Sorry for my ignorance, I'm new to HD's. I have the Service Manual but don't see anything on this.
post #4 of 6 (permalink) Old 09-14-2010, 03:11 PM
You didn't indicate what type of oil you used but its possible that you might have gotten some oil on the O2 sensors and it didn't burn off and that might have thrown a code. You might pull them out and look at them and see if that are oil coated or even stained. It usually only happens when you are running Synthetics when this might happen because it doesn't burn off like regular Dino oil does when it enters into your combustion chamber or maybe depending on how much it was overfilled it could have been sucked up into a oil galley......
twowheel99 is offline
post #5 of 6 (permalink) Old 09-14-2010, 03:25 PM Thread Starter
Thanks all. I'm using conventional oil and it was overfilled at least 1/2 qt. I noticed this morning it does still spit some oil into the air cleaner. I'll check an O2 senser, but I think it may be related to the oil spitting into the air cleaner and restricting air flow, maybe??? Would this cause a "check engine" light / code? How do I get the oil to stop entering the air cleaner?
post #6 of 6 (permalink) Old 09-15-2010, 08:01 AM
HD-DOC's Avatar
Biker Tom Check your PMs
HD-DOC is offline
Check Engine Light and Battery Light following Jackpot 2-1-2 install PearlBlueUltra Troubleshooting for Road Glides 9 06-15-2014 04:59 PM
check engine and battery light drmudd Troubleshooting for Road Glides 11 04-20-2013 02:08 PM
Check Engine Light Ran8175 Troubleshooting for Road Glides 0 07-17-2011 02:17 PM
05 Roadglide check engine light camperfan Troubleshooting for Road Glides 8 05-03-2011 08:36 AM
Engine check light keeps coming on 2011 RGC madmatt Road Glide Specific Discussions 11 02-14-2011 12:14 AM
