Possible ABS ECU Problem - Road Glide Forums
post #1 of 5 (permalink) Old 09-02-2015, 12:36 PM Thread Starter
All,
I have a 2010 FLTRX with ABS. I had the code C0562, appear. I had tested the stator, voltage regular, and battery, and they all tested good. I then looked at the speed sensor and the plug and the wire 3 inches above the plug, all was good.
I then took it to the dealer after not finding what others have found to be the problem.
Dealer ship tested twice and says ABS ECU is the problem. Any body replaced one before, or have the part number? Dealership wants $950 to replace with labor. They already have the bike over 1 day.
I like saving money!
ptdog is offline
post #2 of 5 (permalink) Old 09-02-2015, 01:55 PM
Originally Posted by ptdog View Post
All,
That's one of the reasons I've opted out on the ABS.
post #3 of 5 (permalink) Old 09-03-2015, 07:49 AM
Phantom6722's Avatar
That's not a bad price if it includes a new ABS unit and labour. HD insist on ABS brakes being bled on their ABS tech unit.
When I enquired at my local dealership to just change the brake fluid and bleed the systems they quote $650.00 due to using the ABS tech unit. At those prices I do my own brakes as per standard brake bleeding procedures and I have had not problems so far. However, replacing the main ABS block you may need to have the dealership bleed the system to ensure all the air comes out of the block. Good luck, let us know the outcome.
Cheers Skip
Phantom6722 is offline
post #4 of 5 (permalink) Old 09-04-2015, 10:22 AM Thread Starter
Final update:
After getting off the phone with the dealer, I quickly researched doing the replacement myself. I quickly learned that I may not save much, and would cause more downtime. It was best to get it done, and get it done right, especially with ABS.
The replacement of the ABS ECM did fix the problem. In my opinion, it was worth the cost and fair.
I wished it was the simpler solution, soldering a potential broken wire above the plug. It was not the case.
ptdog is offline
post #5 of 5 (permalink) Old 09-05-2015, 11:36 AM
Good to hear the problems fixed. That's one of the reasons I keep my extended warranty going.
If you're going to change your brake fluids in future just use the standard bleeding procedure for normal brakes. I use a mighty-vac just make sure no air gets into the brake system.
Cheers Skip
J&P Possible Problem DOOFUS Web Sites We Like! 8 03-02-2012 12:42 PM
2011 RG, frt end wobble 40-45 mph, bad ECU sheriff61 Road Glide Specific Discussions 19 12-13-2011 03:19 PM
fltrx ecu w/stage one flash $110 shipped swaite Classifieds Archive (3 months old+) 0 09-26-2011 08:17 AM
Rinehart Exhaust ECU Question G Intake and Exhaust 5 02-02-2011 10:38 PM
Stock ECU & VH Fuelpak vs T-Max Autotune DAK47 ECM/Fuel Management systems 3 12-03-2010 10:48 PM
