Bike want move in gear!! - Road Glide Forums
post #1 of 10 (permalink) Old 09-11-2015, 12:55 PM Thread Starter
Hi all, have 2008 road glide no issues until now. Was out for a ride on the I95. As I shifted into 5th gear I noticed the bike had no pickup but was still cruising. After a few seconds bike just started to slow down. Downshifting/Upshifting had no effect. I coasted off at the exit and stopped the bike. Put bike in neutral and back in first, bike just revs but want move no matter what gear it is in. Anyone encountered this or have idea where to start. I have been running homemade exhaust for about a mouth could this have damaged the engine?
teeboz is offline
post #2 of 10 (permalink) Old 09-11-2015, 01:01 PM
FrankieB's Avatar
The adjuster screw could have backed out or might be time to replace the friction plates.
06 RK
11 RGU
FrankieB is offline
post #3 of 10 (permalink) Old 09-11-2015, 01:12 PM
71u140's Avatar
Check to see if you lost the rear drive belt.
'13FLTRX103, Pro Stage IV kit, V&H slip-ons, 10" Chubby apes, EG Ultra Tour Pak, RG lowers, more to come!
71u140 is offline
post #4 of 10 (permalink) Old 09-11-2015, 05:07 PM Thread Starter
Belt is still in place.
teeboz is offline
post #5 of 10 (permalink) Old 09-11-2015, 05:12 PM
Warpath 41's Avatar
Sounds like the clutch took a vacation. How many miles on it?
[SIGPIC[/SIGPIC]2013 Candy Orange RGC-Power Vison Tuner, De-Catted Head Pipe, Jackpot 4" Slip-Ons, Fuel Moto Billet A/C, Wild 1 502 Chubby's, Painted Inner, Color Matched Vented Lowers w/Boom Speakers, 12" Windvest..........
Warpath 41 is offline
post #6 of 10 (permalink) Old 09-11-2015, 05:50 PM Thread Starter
Miles
Bike has 39000 miles on it.
teeboz is offline
post #7 of 10 (permalink) Old 09-11-2015, 06:11 PM Thread Starter
Okay sometimes it is the simple things..some how the clutch line nut had backed itself out.
thanks all for the help.
teeboz is offline
post #8 of 10 (permalink) Old 09-11-2015, 06:27 PM
Does the clutch pull in like it always did?? If the clutch adjustment is off then you would notice more play in the clutch lever. It could be a stripped clutch hub or transmission input shaft. If it was the transmission chance are you would hear a lot of noise and the problem would be in one gear first instead of all the gears.
I would pull the outer primary cover and do a inspection first thing if the clutch pull is normal.
post #9 of 10 (permalink) Old 09-11-2015, 06:43 PM
Check the rear sprocket. I seen them break away from the wheel. Jack it up and check it.
post #10 of 10 (permalink) Old 09-17-2015, 06:51 PM
lil chief's Avatar
As stated check the rear belt sprocket & make sure the bolts didnt get sheared off. If that aint it your gonna have to dive into the primary. When you put it in gear does it still click like its going into gear? You might have stripped the transmission pulley somehow. Is there any abnormal noises that you are hearing? There are a few things that could be wrong here.
Lil Chief
lil chief is offline
Need to move my bike Kiley Wanted! (Buy or Trade) 10 04-15-2017 08:31 AM
Heated Gear and Rain Gear Stag556 Miscellaneous for Sale 7 10-27-2016 09:15 AM
Brakes rubbing bike hard to move Othello7213 Troubleshooting for Road Glides 1 04-02-2015 07:37 AM
Notice more people move out of my way on highway with RG now??? jbrawkus *General Road Glide Discussions/Pictures 20 01-15-2014 05:16 PM
Want to move down and back. Options? Halstem1 Seating: seats, backrests 17 08-09-2013 04:53 PM
