Limp Mode - Road Glide Forums
post #1 of 12 (permalink) Old 09-21-2015, 01:18 AM Thread Starter
hd4cruzin's Avatar
Limp Mode
Hopefully, the group will give me some ideas as to my issue:
I was cruising along at about 50mph when all of a sudden I lost throttle. Bike was running but no throttle. I now know what Limp mode feels like. Well I was 1.5 miles from a HD dealer and made it to service on a Sunday.
Asked the serive intake guy if he could pull the codes. He disconnected the plug behind the A/C and put on some dielectric grease and reinstalled. Still same problem. He says its 99% probably the Induction module.
I ask, do you stock them? NOPE. Talk to Parts guy and he found another dealer that has one, but will have to wait until Tuesday when they open.
By that time I go back to service and the guy has pulled the codes:
P0152 Rear Oxygen Sensor High/Engine Rich
P0132 Front Oxygen Sensor High/Engine Rich
P0123 Throttle Position Sensor High
P0134 Front Oxygen Sensor Open/ Not responding
P0120 Throttle Position Sensor 1 Range Error
P0220 Throttle Position Sensor 2 Range Error
P0222 Throttle Position Sensor Open/Low
P1511 Throttle Actuator Control Power management Mode
P2107 Throttle Actuator Control Module Processor Fault
So based on the codes above, Does that sound like what it is? Not that I don't trust them. Lol
The waiting is killing me. I'll be 1-2 days behind on my trip to Street Vibrations.
Thanks,
Bill
2012 FLTRX BBP
hd4cruzin is offline
post #2 of 12 (permalink) Old 09-21-2015, 07:37 AM
Do you still have the bike in your possession or did you leave at the dealer? If it was me, I'd clear all the codes and start the bike to see how it runs and if any codes come back. Is there a tuner on the bike?
post #3 of 12 (permalink) Old 09-21-2015, 09:15 AM Thread Starter
hd4cruzin's Avatar
I left the bike at the dealer. Yes, I have a TTS on it since first picking up the bike in Nov 2011. Never had any problems.
I replaced Bars over 3 years ago and kept little green plug in. Never had a problem.
The is the first Tim is have blown codes.
2012 FLTRX BBP
post #4 of 12 (permalink) Old 09-21-2015, 10:14 AM
Redfish-Joe's Avatar
Mine did that randomly a few times. First time I unplugged the induction module, plugged it back in and made it home where I cleaned and greased the connections. Second time, during the same week, it did it again. Killed it , let it sit, restarted and ran fine and made it home. Pulled codes and said it was the P0220 Throttle Position Sensor 2 Range, Error P0222 Throttle Position Sensor Open/Low among some other codes. I had the TPS replaced and no problems since.
Redfish-Joe is offline
post #5 of 12 (permalink) Old 09-21-2015, 11:09 AM
Did the mechanic clear the codes after cleaning the plug to the induction module ?
post #6 of 12 (permalink) Old 09-21-2015, 12:20 PM
whiff149's Avatar
The first time my bike went into limp mode my wife and I were on the way back to Oklahoma from California. The culprit was a broken wire in the harness that connects to the EFM. You couldn't see that the wire was broken because the sheath was covering it. I got us home by unplugging the harness and plugging it back in to the ECM. Sometimes we would get 5 miles, sometimes 20. That was a long day. Apparently the wiring harness and the bend where the harness connects to the ECM is a little too tight. Fast forward 8 months. My bike (2013, ultra) began going into limp mode shortly after I passed 22,000 miles. I got it to my local HD shop. They switched the tps out ( i have aftermarket bars) but that didn't solve it. The stator burned up, it was replaced... that didn't solve it. All pins in the wiring harness to the EFM were replaced to see if "fretting" was the issue.....nope! They replaced the EFM - nope. The voltage into the ECM was at spec but the voltage out of the ECM was variable? But I believe it has been fixed now. Apparently on the touring bikes there is a wire spliced in that would go to a jiffy stand sensor. On police bikes there is a jiffy stand sensor, on all other touring bikes the wire is just there and connected to nothing. They terminated that wire and wrapped it and (knock on wood) that seems to have solved it. the bike was in and out of the shop over a 3 month period. I'd ride it after a parts swap and it would go into limp mode again.
I want to give props to the Dealership Forman's Harley Davidson - Stillwater OK. my bike was out of warranty by a week when this all started and they did all of this parts and labor on "Good Faith".
whiff149 is offline
post #7 of 12 (permalink) Old 09-21-2015, 12:26 PM
whiff149's Avatar
oh yeah. I had a custom power vision map from Fuel Moto for my set up. When the ECM was changed I had to contact Dyno Jet and verify that the ECM had been switched. Dyno Jet sent me an "unlock" file to allow my PV to marry the new ECM and Fuel Moto sent me the needed map immediately. Both had great customer service
whiff149 is offline
post #8 of 12 (permalink) Old 09-21-2015, 01:21 PM
I'd clean up the plug, check the pins, add grease, clear codes and reset throttle then try it. If that isn't it read codes and then I would try a TPS. Next check continuity between sensor and module to find a broken wire.
2013 Ultra
Pics here:
rg_dave is offline
post #9 of 12 (permalink) Old 09-21-2015, 03:49 PM Thread Starter
hd4cruzin's Avatar
I'm going to be at Dealer when they open tomorrow at 9AM to check all that out. I have a line on a new Induction module that is at another dealer about 35 minutes away, incase that is needed.
Need to get bike fixed as I'm already 24 hours behind schedule trying to get to Street Vibrations. Lol
2012 FLTRX BBP
post #10 of 12 (permalink) Old 09-21-2015, 06:56 PM
Life Member With a Grey Beard
SharknoseScott's Avatar
Forget the induction module. You need a new bike.
Old Road Harley is open tomorrow; sales earlier than parts I would suspect...
Once I make up my mind, I'm full of indecision.
SharknoseScott is offline
Limp mode P1510 Mrgoodearth1 Troubleshooting for Road Glides 3 11-03-2017 03:40 PM
Limp Mode scorpiohd *General Road Glide Discussions/Pictures 5 01-11-2016 02:12 PM
Limp Mode Solution ODA CDR (RET) *General Road Glide Discussions/Pictures 4 07-20-2012 07:22 AM
limp mode teepee Troubleshooting for Road Glides 9 07-28-2011 10:38 AM
Hester Went intoi Limp Home Mode - Insight? Shrug *General Road Glide Discussions/Pictures 21 06-15-2011 08:21 PM
