Voltage Regulator??? - Road Glide Forums
post #1 of 6 (permalink) Old 09-28-2015, 01:40 PM Thread Starter
mouser58's Avatar
On my last 3 rides, when I leave the house, within a mile or 2 the Check engine and Voltage lights come on..Volt gauge says less than 12 volts.. when I shut it off, wait 30 seconds or so and fire it back up, everything back to normal..I can shut it off at stops throughout the day and will be fine...
2012 Ultra...Stage 1...Vance & Hines Power Duals,SE Night Sticks, V&H Digital, Stock air box with larger fliter..
mouser58 is offline
post #2 of 6 (permalink) Old 09-28-2015, 01:54 PM
tdkkart's Avatar
2012 bikes had issues with their voltage regulators for awhile. I believe there was a recall covering the replacement if there was a problem.
Check with your dealer.
tdkkart is offline
post #3 of 6 (permalink) Old 09-28-2015, 02:05 PM
Check to make sure all connections are clean & tight. If they're all good, it's probably the VR going bad.
post #4 of 6 (permalink) Old 09-28-2015, 02:05 PM Thread Starter
mouser58's Avatar
Thanks !!!
mouser58 is offline
post #5 of 6 (permalink) Old 09-28-2015, 03:35 PM
Stick_FSMC's Avatar
I had the same thing happen on my 2012 RGU. Just before the Service Bulletin went out. Dealer took care of it under warranty with no hassles.
Good Luck with yours.
Stick
USAF 1980-84
Stick_FSMC is offline
post #6 of 6 (permalink) Old 09-28-2015, 03:51 PM
HellInABucket's Avatar
You can register as the owner of the VIN on h-d.com, it will tell you if it qualifies for the VR product program.
HellInABucket is online now
M1325 Voltage Regulator Recall on 2012 Models CVOVIC *General Road Glide Discussions/Pictures 83 11-22-2012 10:58 PM
While I was getting my voltage regulator replaced.... BigDeez *General Road Glide Discussions/Pictures 16 06-26-2012 07:25 PM
Voltage Regulator Recal Gary R *General Road Glide Discussions/Pictures 18 06-10-2012 09:21 PM
Another Voltage regulator gone bad!!! denis75 *General Road Glide Discussions/Pictures 26 05-31-2012 03:20 AM
Voltage Regulator x 2, Battery x 1 RobDonato *General Road Glide Discussions/Pictures 8 05-07-2012 01:13 PM
