WTH!!! Bike wont start??? - Road Glide Forums
post #1 of 6 (permalink) Old 10-11-2015, 10:33 PM Thread Starter
Exclamation WTH!!! Bike wont start???
2015 RGS...Removed air cleaner and cleaner backing plate. Disconnected harness connection from throttle body. Reconnected and reinstalled everything and bike wont start??!! So Do I have to disconnect battery to have something reset beings I disconnected harness to throttle body? Any thoughts????!!!!
DWILPAT is offline
post #2 of 6 (permalink) Old 10-11-2015, 10:39 PM
chromedome's Avatar
Key fob battery
2012 Road Glide Ultra (SOLD) & 2015 BMW R1200RT
chromedome is offline
post #3 of 6 (permalink) Old 10-11-2015, 10:42 PM Thread Starter
[QUOTE=chromedome;2997122]Key fob battery
negative... fob on bike, system comes on, bike turns over...
DWILPAT is offline
post #4 of 6 (permalink) Old 10-11-2015, 11:43 PM
Do you hear the fuel pump prime when you hit the switch? Is it getting spark? Pull a plug wire off and hold it about 1/4 inch away from the plug and crank it over. If there's spark you'll hear it snapping and probably see it spark. If there is spark. Or use an in line spark tester if you're afraid to hold the wire while cranking
post #5 of 6 (permalink) Old 10-12-2015, 12:13 AM
Paul's Road Glide's Avatar
Is it in gear?
Paul's Road Glide is online now
post #6 of 6 (permalink) Old 10-12-2015, 11:06 AM
staush's Avatar
Go back and redo everything you did. Double check pins on connectors.
staush is offline
bike wont start when hot. junk runner jr Troubleshooting for Road Glides 5 07-14-2014 03:56 PM
Bike wont start Bluchevypick Troubleshooting for Road Glides 50 01-26-2014 01:15 AM
2012 RGU wont start after cam swap Bluchevypick Troubleshooting for Road Glides 5 04-20-2012 11:35 PM
changed bars now bike wont start NO4NBIKES Controls & Handlebars 4 01-02-2012 11:06 AM
wont start The instigator Road Glide Specific Discussions 8 03-24-2011 10:20 PM
