new member new glide new problem - Road Glide Forums
post #1 of 7 (permalink) Old 09-24-2010, 10:43 AM
CROSS
Guest
Posts: n/a
Hello ,, everyone ,, just registered in here ,, been ridin last 22 yrs ,, i have a 74 shovel,, 97 dyna ,, and just got a 1999 road glide do those fairings ever spoil ya ,, im in Newfoundland ,, question for ya ,, lst night well out with the warden i had on the acces lights and they blew the 15 amp fuse in under the seat ,, is this a common thing that ppl encounter or what ,, it seems the more options the more problems ,, anything in particuar to check for Thanks Dave
post #2 of 7 (permalink) Old 09-24-2010, 10:47 AM
Admin
BillyBob's Avatar
welcome mate, don't think it's common but there are some people here who can answer it better than I. Hopefully they'll chime in.
Welcome to the darkside
BillyBob is offline
post #3 of 7 (permalink) Old 09-24-2010, 11:27 AM
CROSS
Guest
Posts: n/a
Question
Thanks for the welcome ,, i just went and picked up another fuse to see if it was a bad fuse .... Not llikely it blew right away ,,,, all other lights work stereo everything what the hell did i get myself into before i start go into it any obvious places you check Thanks
post #4 of 7 (permalink) Old 09-24-2010, 11:31 AM
BigDaveOnBass's Avatar
Send a message via Yahoo to BigDaveOnBass
Accessory lights? Extra lights above and beyond the factory lights? If so, sounds like a grounding issue. Or the fuse can't handle the extra load from the lights. I'd say try a 20 amp fuse, but that may lead to melted wires if it is a ground issue.
'04 FLTRI, originally Smokey Gold, now Vivid Black, 95", S/E forged high comp 9.6:1 pistons, Andrews 37G cams, Big Boyz heads, S/E adjustable pushrods, S/E Race Tuner, S/E Stage 1 kit, V&H Dresser Duals, S/E slip ons, H-D premium oil cooler, chromed wagon wheels, Brembo/H-D front brakes, added rear engine guards, Paul Yaffe 10" OEM Monkey Bars, detachable tour pak
BigDaveOnBass is offline
post #5 of 7 (permalink) Old 09-24-2010, 11:43 AM
CROSS
Guest
Posts: n/a
yEah there fog lights i believe i dint realize they didnt come witout them ill give ya a pic later Thanks man il check for ground and burrs
post #6 of 7 (permalink) Old 09-24-2010, 02:12 PM
Shrug's Avatar
+1 Ground issue. If they're add-on lights, can you just re-run the circuit using existing wiring? You'll likely uncover the problem if you do.
Welcome to the shark frenzy!
Shrug - Scott Wilson
2010 FLTRX "Hester 2.0" -
Shrug is offline
post #7 of 7 (permalink) Old 09-24-2010, 08:32 PM
CROSS
Guest
Posts: n/a
Thanks headin out to rewire right know
2005 FLHT Electra Glide Standard electrical problem - FAST Help needed FLTRXpilot Troubleshooting for Road Glides 4 03-07-2014 03:20 PM
08 Electra Glide - Cruise Control Problem gaillarry Controls & Handlebars 7 03-29-2013 04:34 PM
08 glide Power Commander mounting problem skidmark1964 Troubleshooting for Road Glides 0 09-14-2012 12:40 PM
04 road glide cruise problem fatboyjdb Troubleshooting for Road Glides 1 06-22-2011 08:42 PM
Another problem with the Glide BDMastiff *General Road Glide Discussions/Pictures 5 09-30-2010 04:09 PM
