Stripped out drain plug threads - Road Glide Forums
post #1 of 17 (permalink) Old 10-29-2015, 11:35 AM Thread Starter
Anyone ever strip out the treads for the primary drain plug? Apparently I just did. The drain plug threaded in fine but would not tight in the primary. I backed the plug out and found the aluminum primary threads wrapped around the drain plug threads. Has anyone ever try to heli-coil the primary threads? I bought a heli-coil thread repair kit but I'm not going to have time to mess with it this week as my work schedule this week is crazy. I'll probably get to it on sunday. Just more crap I have to add to the already big pile
post #2 of 17 (permalink) Old 10-29-2015, 11:50 AM
Lucks not your lady.
post #3 of 17 (permalink) Old 10-29-2015, 12:09 PM
James's Avatar
I would think it would work just fine. I remember when I was 16 and on a trip to South Dakota, my mom's pos berreta spit out a spark plug. We happened to coast into a local shops driveway. We can replace the head or use a heli-coil. Heli-coil it is. Worked fine.
James is offline
post #4 of 17 (permalink) Old 10-29-2015, 12:14 PM Thread Starter
I am a 22+ year mechanic and have dealt with heli-coils several times throughout my career, its sorta inevitable I guess. It just sucks when you have to do it with your own stuff.
post #5 of 17 (permalink) Old 10-29-2015, 12:48 PM
Had this happen on my streetglide. It was like it never got tight and the threads came out on the plug. Used a torquewrench. Very easy solution is to get a self tapping oversized plug at the autoparts store. Much easier than a helicoil. Worked great for me. Had it in that bike for more than 50,000 miles.
2013 Ultra
Pics here:
rg_dave is offline
post #6 of 17 (permalink) Old 10-29-2015, 01:07 PM
Mine on either bike will/have bottomed out tight
Little tef tape and flush one thread in has been working
reds4 is offline
post #7 of 17 (permalink) Old 10-29-2015, 02:03 PM
Stick a wad of bubble gum in the hole and smooth it out
reds4 likes this.
post #8 of 17 (permalink) Old 10-29-2015, 03:01 PM
Smarty's Avatar
I never try to tighten the drain plug on the primary. I put Teflon tape on it and screw it in flush. Done.
Smarty is offline
post #9 of 17 (permalink) Old 10-29-2015, 03:08 PM
I would try the oversize drain plug first. A helicoil would work but the timesert is a better fix but it is a little more expensive. You can also weld the hole and drill and tap as a last resort.
post #10 of 17 (permalink) Old 10-29-2015, 08:34 PM
BDMastiff's Avatar
I never had it happen but maybe because I'm always so careful not to strip the threads. I like the idea of an oversized self-tapping drain plug.
1996 Fatboy
BDMastiff is offline
Oil Drain Plug Size (threads) JRB_RME5 Do-IT-Yourself 0 12-29-2014 09:28 PM
Partially stripped transmission drain - best fix? HD_Shock Troubleshooting for Road Glides 18 09-09-2013 01:37 AM
Stripped fairing threads 1Bordercreek Paint & Bodywork Section 5 05-15-2013 07:03 PM
Stripped threads on fairing brackets Monkeyman *General Road Glide Discussions/Pictures 8 02-02-2012 12:54 PM
