Rear Brakes...wtf - Road Glide Forums
post #1 of 9 (permalink) Old 11-06-2015, 04:28 PM Thread Starter
Rear Brakes...wtf
Afternoon Forum!
I rode my 2012 FLTRU today. Had been a couple days as I've been riding my other bikes. The last time I rode, all was well. Today, I hit the rear brake...there was no brake. No brake warning light on dash, nothing at all indicating a problem.
I was able to stop as the front brake is working fine.
Read about a HD rear brake recall being issued in 2011. Seems it affected 2012 too. If I am dealing with that problem, the Stealer didn't check for recalls while they had the bike on the sales floor.
I have the extended warranty so it's definitely headed to the shop.
Thought I would ask you guys if you've experienced similar circumstances?
Have a great weekend!
12 Road Glide Ultra - Ember Red Sunglo
98 Heritage Springer - Blue on Black
06 Yamaha FJR1300 - Dark Purplish Blue Metallic
GRider is offline
post #2 of 9 (permalink) Old 11-06-2015, 04:29 PM Thread Starter
Only had the bike a month and a half...sucks!
GRider is offline
post #3 of 9 (permalink) Old 11-06-2015, 04:34 PM
Had the same issue on my glide which is a 13. I bled the rear and it worked fine. What I determined is that since I almost never use the rear brake it gets a little air in it and stops working so now I use the rear while sitting at stop lights to keep this from happening.
Not sure what year the rear brake switch recall was but I doubt that is your issue as that would affect the brake light coming on, not the actual function of the brakes. Bleed it and ride. Pump it up before you start to ride if it feels spongy.
HogPro is offline
post #4 of 9 (permalink) Old 11-06-2015, 04:38 PM Thread Starter
Thanks HogPro...I did pump the hell out of rear. Didn't stiffen up.
I'll bleed the brakes over the weekend see if that's the issue. I hope it's that simple!
Appreciate the advice Brother!
GRider is offline
post #5 of 9 (permalink) Old 11-06-2015, 05:03 PM
I had this happen multiple times and decided it was my lack of use of the rear brakes after bleeding it the second time in the middle of a road trip.
HogPro is offline
post #6 of 9 (permalink) Old 11-06-2015, 05:08 PM
100edition's Avatar
It's your RG being jealous "your other "bikes riding time.
100edition is offline
post #7 of 9 (permalink) Old 11-06-2015, 05:22 PM Thread Starter
HogPro...Thanks again!
100edition...that cracked me up; she's a jealous b****!!...thanks!
GRider is offline
post #8 of 9 (permalink) Old 11-06-2015, 05:53 PM
Recall a switch defect back in 03, but won't think it would affect the mechanics of brakes, was quite common for us to adjust so we could be on the back brake before the light came on....just to avoid those Blue lights. Definitely ck your caliber
reds4 is offline
post #9 of 9 (permalink) Old 11-08-2015, 01:33 PM Thread Starter
Thanks reds4!
GRider is offline
rear brakes sj01fltri Do-IT-Yourself 22 05-11-2017 09:51 PM
Rear brakes worn out 14k. Hot rotor seahoch Troubleshooting for Road Glides 11 04-06-2014 01:30 PM
Stunt bike rear brakes throttles&triggers General Off-Topic Discussions 3 01-26-2014 09:49 PM
Tire change = no rear brakes exammo Troubleshooting for Road Glides 11 10-12-2012 05:11 PM
7mm 12 point socket for rear brakes?? Kobrak *General Road Glide Discussions/Pictures 7 04-02-2011 11:29 AM
