Shifter arm loose but functioning - Road Glide Forums
post #1 of 17 (permalink) Old 11-07-2015, 10:37 PM Thread Starter
laxinharley's Avatar
Hey guys, i know its common but not quite sure if anyone has a good solution. My shifter arm between the tranny and primary is very loose front to back sliding on the shaft. I replaced the pinch bolt on the arm and it held for like a day. Shifting is perfect no hesitation or anything. Rode about 200miles Thursday and was great. To be honest this has probably been an all summer issue that I just happened to notice now. Anyone tried "the better lever" or have solution or how too. Thanks.
laxinharley is offline
post #2 of 17 (permalink) Old 11-07-2015, 11:08 PM
idahointrudr's Avatar
I would spend the 200 on the better lever and be done with it.
Just my 2 cents!!!! Its your 200 dollars.
2013 BBP TTS Tuner, Andrews 222 cams. Black Heritage bars, Dragos H Pipe, Madstad shield, Sanchos Wings
idahointrudr is offline
post #3 of 17 (permalink) Old 11-08-2015, 06:15 AM
Ohiobellboy's Avatar
What is this 'better lever' you guys speak of?
A.K.A OBB
Ohiobellboy is offline
post #4 of 17 (permalink) Old 11-08-2015, 08:24 AM Thread Starter
It's basically a better design. It's 2 piece, 2 bolt stainless steel arm as opposed to HD aluminum. It has two tightening pieces so it's supposed to clamp better. It also can be put on without removing primary. Just have to cut old one off.
post #5 of 17 (permalink) Old 11-08-2015, 08:24 AM Thread Starter
I'm leaning that way but nervous I messed up something with the arm being so lose so long.
post #6 of 17 (permalink) Old 11-08-2015, 09:09 AM
Smarty's Avatar
I have an 04 that I have had this problem with. Solved it by putting a hardened grade allen bolt, placing a little grease under the head, then cranked it down really tight. No more issues. If this is done right, you will never have another problem. The stock bolt stretches I think and you can't really tighten it down like it needs to be. If you get it as tight as I have, you will never have a spline strip out.
Smarty is offline
post #7 of 17 (permalink) Old 11-08-2015, 10:36 PM
I had the same issue. Purchased a new lever & new bolt, problem solved. I looked at the better lever, good design but it was way to heavy, IMO.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #8 of 17 (permalink) Old 11-09-2015, 10:50 AM
glide69's Avatar
If its rear lever use washer and a hex head bolt and crank the piss out of it. Did this on mine a couple years ago and haven't touched it since.
2018 FLTRXS Wicked Red
glide69 is offline
post #9 of 17 (permalink) Old 11-09-2015, 02:45 PM
Some pics for you Lax, also bad place for a rock
reds4 is offline
post #10 of 17 (permalink) Old 11-09-2015, 03:00 PM
Or fail to retrieve, it's hell on the belt or even worse. .........
reds4 is offline
Shifter arm/rod issue Ibdman21 Troubleshooting for Road Glides 16 07-25-2018 08:55 AM
SERT Tuner Obsolete, Not functioning, Buy new Tuner? hawk06Glide Dyno Results 22 04-04-2016 01:22 PM
Shifter linkage came loose! jcarruth Troubleshooting for Road Glides 18 10-26-2015 08:03 PM
Shifter Arm Flew Off firehouse18 Troubleshooting for Road Glides 14 01-21-2013 11:59 AM
Battistinis FloorBoards-Heel&Toe Shifter-Brake Arm Sikk1 Equipment-RG 6 09-10-2012 11:29 AM
