left turn signal - Road Glide Forums
post #1 of 15 (permalink) Old 09-27-2010, 04:18 AM Thread Starter
left turn signal
ok folks, gotta gremlin! when i try to use left turn signal, the security light comes on? bike runs great. security light goes out at start up and stays out till i try to use left turn signal. i changed bulbs, no help. ???????
rdbateman is offline
post #2 of 15 (permalink) Old 09-27-2010, 10:21 AM
CHAINSAW's Avatar
Have you checked/changed both your front and back bulbs? Are you running standard bulbs, or LEDs?
Mine did this when I installed LEDs in the front, along with a fast blink after a couple of seconds. Once I put load equalizers on, it worked fine. Its wired in, that if you have a bulb burned out the security light will come on when you hit that turn signal.
Such is the rule of honor.
CHAINSAW is offline
post #3 of 15 (permalink) Old 09-28-2010, 10:40 AM Thread Starter
Thanks for your help CHAINSAW
I replaced the front light with sylvania 1157 and rear with sylvania 1156 from local auto parts store. I take it these are standard replacement bulbs? Or, do i need to get HD replacements?
post #4 of 15 (permalink) Old 09-28-2010, 11:05 AM
CHAINSAW's Avatar
You don't need to get the HD replacement, the sylvania is fine.
So your turn signals are working now, correct? You turn them on, walk in front and back and make sure they are both working? It could be you just got a bad bulb or there is corrosion on the socket. Its rare, but it happens sometimes that you buy a brand new bulb and its no good out of the package. It could also be, that you installed them wrong,.. again rare and hard to do because of the prongs, but it can be done and they won't work.
CHAINSAW is offline
post #5 of 15 (permalink) Old 09-29-2010, 09:25 PM Thread Starter
no they are not working. i will check for corrosion and change out with new bulbs. thanks
post #6 of 15 (permalink) Old 09-29-2010, 11:52 PM
CHAINSAW's Avatar
Usually you can rattle the bulb next to your ear (if you can hear,.. I can't anymore) and hear if the element is broken. Holding it upside down and looking you will be able to see if something is broken inside.
What is interesting to me,.. neither of them work. What year is your bike?
Also, do the running lights work?
CHAINSAW is offline
post #7 of 15 (permalink) Old 09-30-2010, 01:21 AM
RE: left turn signal
i have the same problem i took my glide to HD and its the signal canceling unit
i dont have the exact name of the part but i can almost guarantee thats what it is
rockydnuts1 is offline
post #8 of 15 (permalink) Old 09-30-2010, 02:39 AM Thread Starter
2006 and yes the running lights work
post #9 of 15 (permalink) Old 09-30-2010, 03:09 AM Thread Starter
post #10 of 15 (permalink) Old 10-01-2010, 12:19 AM
CHAINSAW's Avatar
I think this guy is on track on what the problem is. Doesn't sound like the bulbs since you have running lights. I wish I could be more help, but wiring never has been my thing.
CHAINSAW is offline
Is my left turn signal switch bad??? Dyna-petey Lighting 7 09-22-2017 09:31 PM
Left turn signal will not work justaguy Controls & Handlebars 6 12-31-2013 12:41 AM
Pinched wires, front left signal HellInABucket *General Road Glide Discussions/Pictures 12 06-13-2013 11:21 PM
Going left..... Way left! DarbinCo Troubleshooting for Road Glides 13 09-20-2012 11:16 PM
Left turn signal richrabb *General Road Glide Discussions/Pictures 3 12-14-2011 08:45 AM
